Jet Fuel
Old Apr 21, 2003 | 07:19 PM
sike43's Avatar
Car Info: 03 wrx
Question Jet Fuel
does any one know any thing about jet fuel? can u put in in to a wrx? if so will it hurt anything?
-thanx
Old Apr 21, 2003 | 07:24 PM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
DO NOT DO IT.....
-gagan
Old Apr 21, 2003 | 07:25 PM
sike43's Avatar
Car Info: 03 wrx
thx
thx i was just wonderin about it where can i get high octane fuel?
Old Apr 21, 2003 | 10:24 PM
128d's Avatar
Car Info: full race 02 Prodrive widebody with 2.5 Cosworth
It is doable, however your engine will overheat very very quickly. I dont recomend it.
Old Apr 22, 2003 | 06:52 AM
sike43's Avatar
Car Info: 03 wrx
thx
thanx every1 for ur input
Old Apr 22, 2003 | 04:23 PM
BlingBlingBlue's Avatar
Originally posted by RichiQY
very informative thread
anyone heard of effects of putting in Alcohol?
IIRC, the manual states using fuel with more than 10% alcohol is a no no. Alcohol is commonly added to fuel as an oxygenate, but rarely in concentrations greater than 10%. I believe too much alcohol breaks down seals, but I'm really not sure.
As an aside, I was riding with my dad in his work van during the 70's when we ran out of fuel. There we were on the side of the freeway...he pulled a couple gallons of paint thinner out of the back of the van and put it in the gas tank. The van was hard to get started, and it ran like crap, but it got us to the next gas station.
Old Apr 22, 2003 | 08:23 PM
EvoEater's Avatar
Car Info: 03 WRX silver
If you put high octane racing fuel such as 110 or so on the stock timing and turbo pressure your gonna lose power, spark plugs and maybe more. Its basically diesel fuel and diesel engines dont have spark plugslike gas engines. (The higher the octane level the harder it is to ignite, but once it does ignite its more powerful)They ignite by compression, not sparking. In a wrx the fuel would ignite after the spark and maybe even after two sparks which means when it does ignite off compression it could do damage. If the turbo boost is upped to about 19 psi and ran with 105 octane level (unleaded) the compression and spark timing even out nicely, so I have discovered.
