Sponsored by:
Sponsored by:
Idle problem
Old 03-22-2015, 12:09 PM
Sfinlay's Avatar
Idle problem
When I start my 2003 WRX it goes to 2.5 thousand RPMS. It stays at 2.5 for about 7 seconds then goes down. After it goes down my check engine light comes on. But if I give it some gas and take it to 3 thousand my check engine light doesn't come on. Has anyone else had this problem? If so how did you fix it? I have tried cleaning the idle air control valve already.
Sfinlay is offline
Old 03-22-2015, 12:38 PM
subysteez's Avatar
Have you checked what the code is?
subysteez is offline
Old 03-22-2015, 01:22 PM
BreadSauce's Avatar
Car Info: 2005 Subaru Wrx STi
Sounds like your throttle cable is too tight, Adjust it. Clear the code and your idle should be 500-700. Make sure you don't adjust it too loose or you will have a hesitation. Also could be a vacuum leak post throttle body. Done any work to the manifold recently? Lines/gaskets?
BreadSauce is offline
Old 03-22-2015, 02:27 PM
Sfinlay's Avatar
It is P1507
I have only replaced the gasket the idle air control valve sits on.
Sfinlay is offline
Old 03-22-2015, 05:49 PM
BreadSauce's Avatar
Yep thats the code. Like I said check the throttle cables for proper adjustment and binding. Any post t/b vacuum hoses appear to be cracked?
Also worth checking the wire that goes to your power steering pump for a loose/bad connection. If you have a code reader that can see the neutral safety switch turn on a off that's worth a check.
If you tap on the valve with a screw driver the idle change at all?
GL_WRX
05-23-2004 10:36 AM
IS300
02-12-2004 09:01 PM
Foot_Tapper
06-15-2003 02:32 PM
Jejunum
16
06-05-2003 09:26 AM
Quick Reply: Idle problem
