i need a subie teacher
Old Jan 16, 2006 | 09:52 PM
jyhighsky's Avatar
intake : short ram vs. cold air? Why? Difference? Does it effect the ECU? Recommendations?
exhaust: turboback vs. catback? Why? Difference? Does it effect the ECU? Recommendations?
suspension: coilover's: Recommendations?
Coolers: FMIC? Recommendations?
Old Jan 16, 2006 | 10:32 PM
VRT MBasile's Avatar
Intake: keep the stock one, its your best bet unless your pushing a lot of power
exhaust: turboback is a larger section which includes the catback. turbo back is everything from the turbo to the end. catback is from the last cat to the end. your real question should be catless or catted.
suspension: if you have the money and the need, get the coilovers.
intercoolers: as with the intake, you only really need a FMIC if youre pussing a lot of power. I had a buddy that put a giant FMIC on his STi and the turbo lag was so horrible that the turbo didnt spool up untill it was almost time to shift. stock TMIC will go far, no real need to change it. If you upgrade to a giant turbo, then you might want to think about a FMIC and an intake.
also, you'll want to get an engine management system (Cobb, Ecutek, something like that)
Old Jan 16, 2006 | 11:01 PM
jyhighsky's Avatar
oh as far as the exhaust question goes.. should the tuboback be catless or catted? and whats that mean hahhahha. which gives you more horespower. i'm guessing catless is "louder"? and catted is silenced im just throwing my 2 cents out there.
Old Jan 17, 2006 | 12:38 AM
ish's Avatar
ish
https://www.i-club.com/forums/engine-management-66/links-info-cold-air-intakes-maf-sensor-59537/
https://www.i-club.com/forums/engine-power-ej20t-pre-2006-wrx-jdm-60/cold-air-intake-debate-36823/
https://www.i-club.com/reviews/showcat.php/cat/2
https://www.i-club.com/reviews/showcat.php/cat/13
and
https://www.i-club.com/forums/a-68/
https://www.i-club.com/reviews/showcat.php/cat/18
Old Jan 17, 2006 | 01:13 AM
2s2ks's Avatar
Car Info: 2002 S2000
Wow, I guess everyone's gotta start somewhere huh? Please use the search button.
Old Jan 18, 2006 | 09:09 AM
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
get cold air intake after u hav alot power, cuz if u get cold air intake rite now, ull have more turbo lag, the longer the pipe the more turbo lag.
Old Jan 18, 2006 | 12:06 PM
^CAI isnt needed at all, the stock air box does a great job. to answer that question about the cat...
catless: has no catalytic converters, which means your car will not pass smogs tests, and will be louder
catted: if you put in high-flow cats (which can be pricey) your car will pass the smog sniffer test (examine the exhaust for polutants) but will still not pass the visual test. the stock cats will rob you of a lot of power, but a aftermarket high-flow cats will only take you down a few hp from catless
Old Jan 18, 2006 | 04:42 PM
Choku Dori's Avatar
Car Info: Corvette Z51
Short ram would involve less worries in this situation, and/or if you're running a front mounted intercooler.
Old Jan 18, 2006 | 06:22 PM
DumbUglyDragon's Avatar
Car Info: Job Wanted!
CAI is useless - you run the air thru an oven/turbo! Reason to have a shortram? When your piping for your front mount gets in the way.
Old Jan 19, 2006 | 10:27 AM
Nose Nuggets's Avatar
Car Info: 03 WRX
CAI will lean out almost any turbo'd car, and could cause SERIOUS problems. rich cars waste gas, lean cars blow engines.
Old Jan 19, 2006 | 11:16 AM
and the search button gets you good answers quickly
crap, I'm starting to sound like a NASIOC'er
Old Jan 19, 2006 | 03:11 PM
Car Info: 03 WRX
yeah i used to be a search natzi when i doing most of my posting over at wrx tuners, but the thread allways degenerated into a repeat of some other thread so i just stoped. if you cant beat em....
shaggadelic
Feb 18, 2006 07:02 PM
OneManArmy
May 20, 2005 01:47 PM
FW Motorsports
Feb 23, 2005 03:32 PM
Max Xevious
Jan 13, 2005 02:00 PM
