FLASHING check engine light
Old Feb 23, 2007 | 04:42 PM
subaruferrucci's Avatar
My car has a flashing check engine light when it is all the way on and when the key is in the acc postion. the car runs fine and stuff. but when the car is in ACC the fans cut on and off randomly and so does the fuel pump. i had the car up on jacks for like a month doing some work on it. was changing the shifter bushings (DONT EVER DO IT CAUSE IT SUCKS TO CHANGE THEM) but i cant figure out what it is and i am little scared to drive it to an advanced auto. i have a 98 impreza L PLZ HELP!!!!!!!
Old Mar 14, 2007 | 12:45 PM
moparbee's Avatar
Car Info: '84 Brat
there is a green, one-wire connector under the dash on the driver's side. when that is connected, the car enters a test mode. this test mode consists of all the relays being tested...including all the accessories and fans. another result of this being connected is the "check engine" light flashing the whole time. cars are delivered from the factory with it connected,a nd as poart of the pre-delivery inspection, it is dis-connected. lots of people, seeing a connector obviously disconnected, react by reaching up and connecting it, thus entering the test mode by accident. go check this connecter, and un-plug it...see if that solves your problems.
~Erik~
Subaru dealer technician
Old Mar 18, 2007 | 05:18 PM
SnoHumper's Avatar
Car Info: sc300
from my understanding a flashing CEL is for a catalyst damaging problem... get code pulled =D
Old Mar 18, 2007 | 08:22 PM
Mulder's Avatar
Car Info: 02 WRX WRB
This is true if the CEL comes on while the car is running. However what is being described here is the diagnostic mode as explained above. In this mode the light will flash constantly when the key is on even with the engine off.
Also FYI the light will flash when an active misfire is detected, however if it remains flashing and does not stay on steadily there may not be any code stored.
Old Mar 18, 2007 | 10:32 PM
Jake's Avatar
whats a catalyst damaging problem?
Old Mar 19, 2007 | 09:03 PM
Mulder's Avatar
Another way to describe an active misfire that is dumping raw fuel into the cats, which can cause them to overheat.
Old Mar 20, 2007 | 03:43 PM
SnoHumper's Avatar
Car Info: sc300
ya wut he said... anything that puts raw fuel into cats
Old Mar 28, 2007 | 06:14 PM
i fixed it it was 2 wires under the dash that should not be connected
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
SubeeTedII
Nov 27, 2004 03:35 PM
Kevex
Feb 6, 2003 07:35 PM
