Antenna Problem on 04
Old Aug 5, 2003 | 02:06 AM
Kuonji's Avatar
Car Info: 2007 Mazdaspeed 3
I just installed a JVC head unit on my 04 STi and plugged the antenna wire into the deck and everything works fine with the unit except I get nothing for reception on FM or AM. It's as though the antenna isn't even there. Could there be a loose antenna connection somewhere in the car? Any help is appreciated. Thanks.
Old Aug 5, 2003 | 03:55 AM
Mulder's Avatar
Car Info: 02 WRX WRB
The '04s have the antenna in the rear window glass and there is an amplifier for the antenna so it works properly. When you install a radio the power antenna wire in the harness must be connected to power the amplilfier so it works. If you used a standard harness adapter it should be the blue/white wire in the harness.
Old Aug 5, 2003 | 08:25 AM
Kuonji's Avatar
That's definitely it. Thanks!
njc200
Jun 24, 2005 06:41 AM
Rokk
Dec 20, 2003 01:11 PM
IS300
Jun 11, 2003 01:51 PM
128d
Feb 8, 2003 07:11 PM
fidDUBrx
Jan 23, 2003 08:08 PM
