Airbag
Old Mar 5, 2013 | 05:30 PM
sapper_tech's Avatar
Airbag
The airbag light won't go off on my 2004 impreza STI. Nothing else is wrong with it cruise control and the horn still works tell me how to get this light off????
Old Mar 5, 2013 | 05:49 PM
orwrx's Avatar
Car Info: WRC replica
Please tell us what mods you have? Aftermarket seat, steering wheel.....etc? If everything stock, then it must have something wrong, otherwise it will not trigger the light. More detail please!
Old Mar 5, 2013 | 05:54 PM
Blazingbuda40's Avatar
Car Info: 2004 Forester XT
happens to me every once and a while, just check under your seat for the airbag wires and mess around with the plug. It should turn off eventually. I have heard that the airbag seat wiring or the connecting plugs arnt that good on subarus but i could be wrong.
Old Mar 6, 2013 | 06:12 AM
Well I just put a remote start in it and a new air filter....everything else is stock minus the stereo.
Old Mar 7, 2013 | 06:42 AM
Mulder's Avatar
Car Info: 02 WRX WRB
When the light is on there is a stored trouble code, same as the check engine light. The code is stored in the airbag module though, and can't be read with an OBDII reader (so you can't go to Autozone or a similar place to have it pulled). A dealer can scan it, also a shop with one of the professional scan tools (i.e. SnapOn) may be able to do so.
There is also a DIY procedure in the service manual where you jump two connectors together and read the code through flashes of the light. I'm not 100% sure if it works on your car.
Since your horn and cruise are working it's probably not the clock spring. As mentioned you can try to reseat the plugs under the seats, sometimes the connections may get dirty or intermittent and set a code. Be sure to do this with the key off and out. If the light goes out after that you probably found the issue, if it stays on you'll need to go further and get the trouble code to point to the faulty component.
BugeyeMilo
Mar 16, 2011 09:06 PM
sykosis
Aug 6, 2005 11:32 PM
sykosis
SoCal Classifieds
Aug 4, 2005 11:35 PM
sykosis
Wanted
Aug 4, 2005 06:04 PM
adamsrs
Subaru OEM Parts For Sale
Dec 4, 2002 01:54 PM
