problems led to more problems
Old Dec 15, 2006 | 12:10 PM
-WickedRex-'s Avatar
Car Info: 2002 Impreza WRX
Exclamation problems led to more problems
when the stock battery died on my 02 wrx with oe security system it used to flash the ambers when turning on/off the alarm. Now that i put a new battery in not only does it not falsh the ambers but a security light on cluster now flashes. the light below the guages never falshed until the new battery was put in. some help please cause i just dont get what happened. i cant find any way to adjust the alarm settings so any thing will help. thanks.
Old Dec 15, 2006 | 12:51 PM
zavier's Avatar
Car Info: 2007 Impreza 2.5i
well the light on the dash behind the steering wheel should blink fast right after activation and then blink once like every 3sec after that till the alarm is turned off...
as for the lights not blinking i have no clue...only think i can think of is that some sensor didn't reset properly when you changed the battery?
Old Dec 16, 2006 | 12:39 AM
when exactly should the light begin to flash cause i think mine flashes as soon as the car is turned off. is it standard for the outside ambers to flash when alarm is turned on/off or is there a way of changing it.
Old Dec 16, 2006 | 04:28 AM
Mulder's Avatar
Car Info: 02 WRX WRB
Your alarm is now in valet mode. Open the drivers door and press the unlock button on the remote for several seconds, this will cancel valet mode and restore normal operation.
Old Dec 18, 2006 | 06:38 PM
Smile
That was it. thanks for the help. oh, so how do u then turn this mode back on, the same way or is there another way cause i wasn't sure when i tried it.
Old Dec 18, 2006 | 06:53 PM
wrexr's Avatar
Car Info: E28M5, RAM Powerwagon, Motos
Valet mode- alarm not operating
Standard mode- alarm operating
To change the alarm mode on or off, same procedure. Hold open/unlock while door is open.
Old Dec 18, 2006 | 06:57 PM
thanks for the help. im still trying to find out why other things on my car are acting funny but as soon i find out what and how be sure that i'll be asking for ur help. thanks
04caliwrx
116
Jan 12, 2012 03:36 PM
Speed Element
Engine and Drivetrain
May 13, 2010 11:10 AM
Daios
Oct 25, 2009 07:18 PM
grex767
May 27, 2006 10:37 AM
PimpWagon
Jan 7, 2003 07:27 PM
