Need help with this car alarm
Car Info: Subaru Impreza WRX
What did you think...????
Crimestopper is proud to introduce our improved CS-2015FM Informer™ for 2003. When it comes to security, convenience, remote starting and 2 Way FM paging, the Informer system has all of the above. With its groundbreaking Dot Matrix screen design, the CS-2015FM stays ahead of the rest, hands down. Step up to a system that uses a fully animated, real time, graphic LCD screen instead of that "painted" icon LCD screen the competition is using. With more new features for 2003, the Informer™ maintains the status quo as the flagship of Crimestopper's 2-Way FM paging technology.
Security Highlights
Electronic Dual Stage / Dual Adjustment shock protection
On Board Flashing Light Relay
Pre-wired Starter Disable Relay and Socket Included
Auto Lock / Unlock with Ignition (programmable)
Door Lock Pulse Time (programmable 1 or 3 sec)
Extended Range On-Glass Antenna / Receiver System
Horn Honk Output
Active or Passive Arming (programmable)
5 / 60 Door Zone Bypass with Warning Chrips
Optional M.A.P. (Mobile Accessories Protection)
Convenience Highlights
Remote Keyless Entry (Controls Power Door Locks)
Positive & Negative Door Lock Outputs (includes 2 IN4005 diodes in kit for extra protection)
2 Remote Auxiliary Outputs (1 Momentary, 1 Pulsed) for Optional Power Trunk Release, Power Window Control Module, Accessories etc.
Dome Light Illumination (requires relay)
SideKick Transmitter now included with CS-2015 FM TW1 (CS-397)
Separate Driver's Priority Door Unlock Output
2 Vehicle Operation allows User to Control Two CS-2015FM Systems from One Remote.
Silent Arm and Disarm Through the Remote
Valet Service & Valet Park Modes.
Programmable Parking Light Illumination on Disarm (Car Finder)
Programmable Double Unlock Pulse
Remote Start Highlights
On Board Remote Start Relays for Easy Installation
Tach Finder Mode
Programmable Self Start Mode Starts Engine Every 4 Hours
Factory Alarm Disarm Output
Gas or Diesel Engine Operation
Negative Outputs for Additional Ignition or Accessory Relays
Selectable Engine Speed Sensing, Tach Mode or "Smart" Tachless Mode
Programmable Engine Run Time of 12,24,36 or 48 Minutes
Infinity Run Mode (Endless Run Time)
Anti Grind Feature - Prevents Accidental Key Grinding
Brake Pedal Reset
Hood Open Safety Circuit. TheUnit Will Not Remote Start if Hood is Open or Ajar
2-Way Paging Features
Compact 5 Button Transceiver Pager / Remote with Backlit LCD Screen
Long Range, Penetrates Through Parking Garages and Shopping Malls.
Vibrating & Audible Pager Alerts
Fully Animated LCD Graphics Display Armed, Disarmed, Zone Violation and Vehicle Running After Remote Start
New CS-2015FM Improved Features
New Pearl Charcoal Gray High Tech Remote Finish
An Additional On Board Remote Start Relay for Powering 2nd IGN or ACC Circuits(Jumper Selectable)
Diesel Delay Time Set for Delayed Cranking in 3 Increments: 10,20, or 30 Seconds for Vehicles Without a Viable Glow Plug Circuit.
Optional Leather Remote / Pager Case with Belt Clip
"Timed" Crank Mode (Pre-set Starter Cranking Time in 4 Increments from 0.5-1.5 seconds)
Positive or Negative Parking Light Output(Jumper Selectable)
Availability: Usually ships the next business day.
CS-2015FM$159.90
.......Is worth the price???????
Security Highlights
Horn Honk Output
Tach Finder Mode
Brake Pedal Reset
CS-2015FM$159.90
I just bought that alarm a few days ago. With shipping, that was about the price i paid. We'll see if it's crap or not once i get it installed (which looks like a major undertaking in and of itself).
Honestly i haven't installed it yet. I purchased it when i purchased my car stereo. I've been spending most of time time on the stereo and havn't done this yet. I'll let you know when i do.
Flipping through the manual, it seems as if it'll take some close attention to detail to install the alarm (ie messing with factory wiring). Personally the remote start install looks scarry. I was thinking about just not installing that part and/or getting some help by an expirienced mechanic before i attempt it. The other parts don't seem that bad (except maybe the relays, but i'll learn about that when i get there :P )
I must purchase one for the single reason of :
go to the link
there's an english translation of the problem )
https://www.i-club.com/forums/showth...442736post442:(
go to the link
there's an english translation of the problem )https://www.i-club.com/forums/showth...442736post442:(
Oh oh! one more impreza stolen an grey Sti 2004
https://www.i-club.com/forums/showth...9552post769552
slim617
Jun 9, 2007 09:38 PM
Soobie22
Jul 8, 2005 03:48 AM
scustoms
Feb 9, 2005 06:17 AM
