Speed Element -- (510)-226-8822 Website -- Click here.
Oil Issue....
Old Oct 16, 2006 | 05:46 PM
1WRXNFX's Avatar
Car Info: 2000 2.5 RS (really slow)
Oil Issue....
Im having an issue with my 05 STI. Recently i replaced my VF39 turbo that had a crack on the exaust side of the turbo. The car was burning oil because of the crack in the turbo so i replaced it with a vf22 which i thought would stop the oil burning/consumption. But im 3000 miles into my vf22 and im still loosing oil (roughly 1300 miles and im bone dry.). I noticed when i get on boost i can see a small amount of smoke comming from my exaust. Any one have any ideas of what could also be causing me to loose oil at a rapid rate? Before the turbo swap (1month before) we did a compression/leak down test on the motor and it came back all good so i know its not a crack in the block. Could it be head gasket or seal rings? Im also not experiencing any random leaks or drip spots so thats whats making it so confusing. Any ideas anyone? Id greatly appreciate it, its really driving me nuts.
Thanks,
Stephen
Old Oct 16, 2006 | 10:20 PM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
Thanks,
Stephen
when you were swapping out the turbos back and forth, did you replace all the gaskets (including oil line return feed gasket etc)?
mpj
Old Oct 23, 2006 | 06:42 PM
1WRXNFX's Avatar
not sure if that happened? i had the turbo replaced by gruppe-s. i assume they would if it were neccessary to properly istall and make the turbo/ and car run appropriatly.
Old Oct 25, 2006 | 12:10 AM
Former Sponsor
Stephen... give us a call and we can schedule you in and see what we can find to see where the oil leak is coming from.
thanks
Devin
MPJ/Speedelement
510-226-8822
huck
Aug 23, 2017 02:18 PM
kyoung05
Jan 31, 2010 11:40 AM
skeescurt
Jul 31, 2007 09:56 PM
Chrisnonstop
Dec 26, 2006 02:29 PM
1WRXNFX
Oct 16, 2006 06:35 PM
