Up pipe stuck! Help!
Old Aug 28, 2012 | 10:42 PM
BMONEY04's Avatar
Car Info: 2004 WRX
Hey guys, so I'm tearin thru a dp/up pipe install and BOOM. Up pipe is stuck. I tried unhooking the motor mounts and jacking the motor but it just keeps lifting my whole car? Anybody know how I can get the lil guy outta there? It still has the EGV connected to pipe, I thought if I got it off, I could jiggle the whole thing out but it's a no go... any tips? I'm so close to Stage II but cant do anything with the stock pipe stuck!!!
Thanks for the advice... local SR people are welcome to come help!
Old Aug 28, 2012 | 10:49 PM
xhengmanx's Avatar
unbolt the pitch stop mount and the passenger side motor mount. Make sure the washer is not stuck on it. Slightly start jacking it up with a piece of wood between the jack and the exhaust manifold and it should move up.
Old Aug 28, 2012 | 11:27 PM
BMONEY04's Avatar
Car Info: 2004 WRX
manifold is un hooked and hanging by zip ties...can I jack right above oil pan?
Old Aug 28, 2012 | 11:47 PM
xhengmanx's Avatar
You can but you rrisk damaging your oil pan. Ill leave that up to you
Old Aug 28, 2012 | 11:56 PM
BMONEY04's Avatar
Car Info: 2004 WRX
above the oil pan...not on it...whats safest spot to jack from?
vsick
May 16, 2011 02:26 PM
fliped wrx
SoCal Classifieds
Jun 8, 2007 10:52 PM
gdbimpreza
Mar 3, 2005 12:12 PM
gdbimpreza
Jan 20, 2005 05:25 PM
push2
Jan 21, 2003 10:56 PM
