The Reverend's shaggin wagon
3 Attachment(s)
A few days after we got him circa November 2011:
[attach]213174[/attach] Favorite recent pictures: Toby hardparked at BAM 2019 (Best Track Prepped) and full boogie at the SCCA SFR Sacramento Bill Fleig Memorial Enduro at Thunderhill 22 September 2019 [attach]213175[/attach] [attach]213176[/attach] [b][i][u]::Final Mod List::[/u][/i][/b] [u]Engine:[/u] ACL Race Main Bearing ACL Race Rod Bearings AEM 3.5 Bar MAP Sensor AEM Air Intake AEM E85 320lph Fuel Pump AEM IAT Sensor Apexi WS2 Noir cat-back exhaust ARP Head Studs Carberry Snail Performance Engine Management/Tune Cobb Catless Downpipe Cobb MAP Sensor Adapter Cobb TD05-20G-8 Turbo Cobb Turbo Heat Shield Deka 16ETXL Mini Battery Delicious Tuning Flex Fuel Kit EQT Oil Pickup Fumoto Oil Pan Drain Gates Timing Belt GrimmSpeed 3-Port Boost Control Solenoid GrimmSpeed Intercooler Shroud GrimmSpeed TMIC Intercooler IAG Street Air-Oil Separator Injector Dynamics ID1300 Fuel Injectors Killer B 4-1 Holy Header And Up Pipe Exhaust Manifold/Header Koyo Radiator Perrin (eww) 2.4" Silicone Turbo Inlet Radium Engineering Fuel Surge Tank With Single AEM 50-1200 E85 Surge Tank Redline Tuning Hood Dampers Rev Motoring Radiator Shroud Subaru OEM 11mm Oil Pump Subaru OEM 2006 STi Connecting Rods Subaru OEM 2006 STi Crankshaft Subaru OEM 2006 STi Oil Pan Subaru OEM 2006 STi Oil Pan Baffle Subaru OEM EQT 5-angle Valves Subaru OEM EQT CnC Chamber Cylinder Head Subaru OEM GrimmSpeed Deleted and Ported Tumble Generator Valves Subaru OEM GrimmSpeed Ported Intake Manifold Turbosmart Dual Port BOV Blow Off Valve Turbosmart Intercooler Hose Kit Turbosmart Throttle Body Hose Wiseco 100mm Forged Pistons [u]Brakes:[/u] Power Stop Track Day Brake Pads Power Stop Track Day Brake Rotors Stop Tech Stainless Braided Brake Lines Subaru OEM 2006 STi Brake Booster Subaru OEM 2007 STi Limited Brembo Black Brake Calipers TurninConcepts Brake Master Cylinder Brace [u]Drivetrain:[/u] Cusco Engine Mounts Cusco Transmission Mount Kartboy 6MT with 3" Extension Short Shifter Kartboy Differential Mount Outrigger Bushings Kartboy Front And Rear Shifter Bushings Kartboy Pitch Stop MapDCCD Center Differential Controller MapDCCD Wheel Speed Sensor Processor Subaru OEM 2006 STi (HX) Differential Subaru OEM 2006 STi Axles Subaru OEM 2006 STi Clutch Subaru OEM 2006 STi Clutch Line Subaru OEM 2006 STi Clutch Master Cylinder Subaru OEM 2006 STi Differential Cover Subaru OEM 2006 STi Driveshaft Subaru OEM 2006 STi Flywheel Subaru OEM 2006 STi Knuckle/Hub Assemblies Subaru OEM 2006 STi Shift Linkage Subaru OEM 2010 STi 6MT UW1MA Transmission TurninConcepts Differential Mount Bushings TurninConcepts Transmission Mount Bushings [u]Suspension:[/u] Carbing Front Lower Arm Bar and Subframe Control Arm Braces Feal 441+ Coilovers Feal Front And Rear Camber Plates Top Hats Kartboy End Links Kartboy Rear Subframe Bolts Oswald Performance Rear Triangle Brace Strut Tower Brace Subaru OEM 2004 STi Lateral Links Subaru OEM 2005 STi Sway Bar Mounts Subaru OEM 2006 STi Control Arms Swift 13K/11K Springs TurninConcepts Fender Braces Whiteline 27mm Front and Rear Sway Bars Whiteline Anti-Lift Kit Whiteline Front LCA Front Bushing Whiteline Lateral Link Bushings Whiteline Roll-Center Adjustment Whiteline Steering Rack Bushings Whiteline Sway Bar Collars Whiteline Trailing Arm Bushings [u]Exterior:[/u] GrimmSpeed Horn Mount Hella Supertone Horn Morimoto D2S XB HID 4300K Low Beam Bulbs NoName 2006 STi V-Limited Rep Front Lip Optilux Halogen XY Series Xenon 3000K Foglight Bulbs Optilux Halogen XY Series Xenon 3000K High Beam Bulbs Phork/Team Moist Front Splitter Rally Armor 3/16" Steel Underbody Protection Subaru OEM 2006 STi Rear Diffuser Subaru OEM GG Impreza TS Roof Rail Delete Subaru OEM JDM Amber Oval Side Markers Subaru OEM JDM V7 STi Grill Subaru OEM JDM V7 STi Hood Scoop Subaru OEM JDM V7 STi Rain Guards Subaru OEM JDM V7 STi With G5-R Bi-Xenon Projector Headlights Subaru OEM WRB Painted Side Skirts Subyflare/Karlton Fiberglass Fender Flares [u]Interior:[/u] Defi 52mm White Racer Boost/Oil Press/EGT Gauges Pioneer 3.5-way 6.5" Front/2-way 5" Rear Speakers Pioneer DEH-X8600BH Headunit Recaro SRD Black/Black Seat Schroth Racing Rally 4 ASM Seat Harness Subaru OEM EDM V7 STi Prodrive Instrument Cluster Wedge Engineering Seat Bracket/Slider WRXtra 52mm OE Gauge Pod Gauge Pod [u]Wheels and Tires:[/u] ARP Extended 3" Wheel Studs Motegi Racing MR137 18X9.5 +15 Black Wheels (Street) Muteki SR-48 Open-Ended Black Lug Nuts Yokohama Advan Sport A/S 255/35R18 Tires (Street) [u]Future Plans:[/u] [s]AEM E85 340lph (With Hanger) Fuel Pump APR Carbon Fiber Alternator Cover APR Carbon Fiber Radiator Shroud APR Carbon Fiber Rear Diffuser APR Front Bumper Canards Canards APR GT3 Mirrors Boomba Racing 75mm DBC Black Throttle Body Cobb Black Turbo Inlet Cobb FMIC Black Crower/GSC Valve Guides Crower/GSC/Kelford Camshafts Crower/GSC/Kelford Valve Springs and Retainers Cusco Increased Capacity Rear Differential Cover R180 Driveshaft Shop 1-Piece Aluminum Driveshaft Goodridge Stainless Braided Clutch Line GSC Valves Valves IAG 3mm Phenolic Spacers IAG Black Valve Cover Cam Seals Kartboy 15mm Set Exhaust Hangers Kartboy Black Oil Cap Killer B EWG Up Pipe Killer B Pan/Pick Up/Baffle Combo Oil Pan M45 Ported and Polished Cylinder Head MAPerformance/Mocal Stainless With Thermostat Oil Cooler Okada Projects Plasma Direct Ignition Coils Phork/Team Moist ABS Flat Panel Underbody Protection Radium Engineering Single Hanger With AEM 50-1200 E85 Fuel Pump Radium Engineering Subaru EJ Fuel Rail Plumbing Kit Radium Engineering Top Feed Upgrade, Subaru EJ Fuel Rails Samco Radiator Hose Kit Red Sparco 345mm Suede Steering Wheel Splash Hub Adapter Steering Wheel Hub Splash Quick Release Rapfix Steering Wheel Hub Release Turbosmart External Wastegate[/s] [u]Previous/Removed Parts[/u]: --4" delrin shift knob --ACT SS HD clutch kit --Advan RCII 17x8.5 +48 wheels white with Federal SS595 225/45/17 tires --AEM 5 bar [url=http://i.viglink.com/?key=c59c28ee053b9c20874b223ea8f1cb26&insertId=e93263aca346a9fe&type=L&exp=60%3ACI1C55A%3A11&libId=k0wp9vrl01000b2g000DAcchngkw1&loc=https%3A%2F%2Fwww.i-club.com%2Fforums%2Fongoing-projects-31%2Freverends-shaggin-wagon-245193%2F&v=1&iid=e93263aca346a9fe&opt=true&out=http%3A%2F%2Fwww.amazon.com%2Fs%2Fref%3Dnb_sb_noss%3Furl%3Dsearch-alias%253Dautomotive%26field-keywords%3Dmap%252Bsensor&ref=https%3A%2F%2Fwww.i-club.com%2Fforums%2Fsearch.php%3Fsearchid%3D4810190&title=The%20Reverend%27s%20shaggin%20wagon%20-%20i-Club&txt=%3Cspan%3EMAP%20%3C%2Fspan%3E%3Cspan%3Esensor%3C%2Fspan%3E]MAP sensor[/url] --AEM 52 mm analog AFR, boost, EGT, pressure, and temperature gauges --Apexi GT Spec cat-back exhaust --APS turbo inlet --BC Racing BR series coil overs --Carbotech AX6 brake pads --Centric OEM blank rotors --Cobb Accessport Snail Performance Engine Management/Tune --Continental ExtremeContact DW 245/35/18 tires --Deatschwerks 650 cc fuel injectors --Deatschwerks DW200 255 lph fuel pump --Enkei Nt03+M 17X8 +48 wheels (custom orange powder coat) with Dunlop Direzza ZII 224/45/17 tires --Enkei RCT4 18X8.5 +48 wheels gold with Nexen 2000 235/45/18 Tires --Feal 441 coil overs (9K/7K Swift springs with front and rear camber plates) --Fujitsubo Titanium 3" Catback Exhaust --Gimmick Motorsports 3" V-band cat-back exhaust --Greddy Evo2 cat-back exhaust --GrimmSpeed 3" down pipe-to-OEM cat-back adapter --GrimmSpeed ported exhaust manifolds and hi-flow cross-pipe --Group N 5-speed transmission mount --H&R Sport springs --Hallman Pro Rx manual boost controller --Hankook Ventus RS-3 255/35/18 tires --Hankook Ventus Z214 C91 275/35R18 Tires (Race) --Hawk HP+ brake pads --HKS Silent Hi-Power JASMA cat-back exhaust --Hooptyworks Wood Knob Shift Knob --Injector Dynamics ID1000 1000 cc fuel injectors --Inno Grabmax snowboard rack --Inno small wind fairing --Innovited 3000K HID fog lights --Invidia G200 cat-back exhaust --Invidia N1 Race full titanium cat-back exhaust --Invidia Q300 cat-back exhaust --Invidia up pipe --JNA retrofit polyurethane front lip --K&N Typhoon short ram intake --Kartboy 2-piston caliper adapter --KNS Brembo caliper adapter --KNS STi adapter brake shoes --KW Suspensions Variant3 coil overs --KYB GR-2 struts --Lamin-X green fog light overlays --M2 3” cat-back exhaust --Megan Racing front strut tower brace --Megan Racing lower control arm crossmember brace --Mitsubishi Evo 8 Recaro seats with Wedge Engineering sliders and brackets --Morimoto H1 HID projectors (LHD) --Perrin 25 mm front and rear sway bars --Perrin 3" Sport Tone cat-back exhaust --Perrin 5MT short shifter adapter --Perrin alternator cover --Perrin cat-less down pipe --Perrin front and rear shifter bushings --Perrin intercooler hose kit --Perrin polyurethane front and rear end links --Perrin radiator shroud --Perrin rear sway bar stout mounts --Perrin silicone after-MAF hose --Perrin V1 equal-length header --PIAA ion yellow fog light bulbs --Pioneer 2-way 4" rear speakers --Pioneer AVH-P1400DVD head unit --Pioneer Premier FH-P800BT head unit --Ported throttle body --Prodrive axle-back exhaust --Prodrive urethane mud flaps --RallyArmor basic mud flaps --Rays Gram Lights 57Xtreme 18X10.5 +22 Semi-Gloss Black Wheels (Race) --Rev Motoring alternator cover--broken/garbage --Rota Boost 17X8 +48 wheels (custom steel metallic powder coat) with Bridgestone Potenza RE970AS 245/40/17 tires --Rota DPT 17x9 +42 wheels silver (now pink) with Hankook Ventus RS-3 245/40/17 tires --Rota RT5 17x9 +42 wheels teal with Federal 595 RS-RR 255/40/17 tires --Rota RT5 18X8.5 +44 wheels flat black with Federal 595 RS-RR 245/35/18 tires --Rota Slipstream 17X8.5 +48 wheels flat black with red lip/Time Attack with Hankook Ventus RS-3 245/40/17 tires --RotorPro slotted brake rotors --SMY gauge bezel pod --SPT cat-back exhaust --SPT short ram intake --SSR Professor 18X8.5 +48 wheels with Continental Extremecontact DW 235/35/18 tires --STi axle-back exhaust --StopTech slotted brake rotors --StopTech Street Performance brake pads --Stromung axle-back exhaust --Subaru 2004 STi BBS 17x7.5 +53 wheels gold with Dunlop SP Sport01 235/45/17 OEM GV tires --Subaru 2004 WRX gauge cluster --Subaru 2004 WRX STi gauge cluster --Subaru 2006 WRX front 4- and rear 2-piston brake calipers - Subaru GD STi 5x114 BBS 17x8 +53 wheels gold with Bridgestone RE-71R 245/45/17 tires --Subaru GD STi Brembo calipers (custom red powder coat and white decals) --Subaru GD STi rear aluminum front lateral links --Subaru GD STi shift knob --Subaru GD STi shift linkage --Subaru GD STi top mount intercooler --Subaru GR/GV STi top mount intercooler and y-pipe --Subaru GR/GV STi VF-48 turbo --Subaru JDM STi mesh fog light covers --Subaru OE crossbars --Swift 7k/5k coil over springs --TeamDynamics Motorsports 17X8 +33 wheels anthracite with Continental ExtremeContact DWS 245/40/17 tires --Turbosmart Kompact BPV --TurboXS stealth-back exhaust (Twice… lol) --Walbro 255 lph fuel pump --Whiteline 27mm rear sway bar --Whiteline adjustable front and rear end links --Whiteline adjustable lateral links --Whiteline rear camber bolts --Work Emotion CR 17x8 +47 wheels bronze with Bridgestone RE-71R 245/40/17 tires --Yakima roof basket --Yokohama S-Drive 255/40/17 tires |
Just got back from Ed's:
Event: Dyno Pull Location: Fairfield, California Temp: 98 degrees F Elevation: ~100 feet above sea level Weather: Sunny, warm and 20% humidity Car: Toby Tuner: Ed @ Equilibrium Tuning Dyno Info: Dynocom Transmission: Stock 5 Speed Gear: 3rd Peak Hp at RPM: 275.6 hp @ 5550 rpm Peak Wtq at RPM: 295.8 ft-lbs @ 3900 rpm (stock 02-05 WRXs read around 160 peak hp on this dyno according to Ed) Fuel: 91 octane hippie-juice Target boost: 17.5 psi peak tapering to 15 psi [IMG]https://sphotos-b.xx.fbcdn.net/hphotos-ash4/224546_10151043573297750_786838362_n.jpg[/IMG] |
2 Attachment(s)
Couple pictures from today screwing around with #instagram:
[attach]213172[/attach] [attach]213173[/attach] |
Looking good Rob!
Thanks, Ed.
Total sleeper! I bet that 270whp makes it fell like a rocket!! Nice build
wow awesome build, deff going with the hybrid route also. Any particular reason you chose the vf-48??
[QUOTE=04caliwrx;3313294]Total sleeper! I bet that 270whp makes it fell like a rocket!! Nice build[/QUOTE]
Thanks. That's pretty much what we're going for. My wife refuses to drive it. Says it's too fast. : banana : [QUOTE=92xsaabaru;3313324]wow awesome build, deff going with the hybrid route also. Any particular reason you chose the vf-48??[/QUOTE] Thanks. Primary reason is it's OEM. That, and Ed recommended it over a 16g. He's tuning it, might as well go with what he recommends. |
1 Attachment(s)
I am the luckiest man alive.
Birthday/Early Christmas gifts from the wife: [attach]213171[/attach] Team Dynamics Motorsports 17x8 +33 wrapped in 245/45 Continental DWS! ..AND she helped put them on. Nothing sexier than a woman wielding an impact gun! Better pictures tomorrow(ish). |
3 Attachment(s)
[attach]213168[/attach]
[attach]213169[/attach] [attach]213170[/attach] |
1 Attachment(s)
The woman really is spoiling me this year. My Christmas gifts:
[attach]213167[/attach] In the middle of putting these on, out of nowhere the wife says to me: "So, what would we need to do to this to run E85?" Dear God, I love this woman. |
Sounds like a keeper!!
You just need injectors and a tune :D -- Ed |
1 Attachment(s)
New air brakes.
[attach]213166[/attach] |
3 Attachment(s)
Couple new additions for the New Year.
Replica STi strut tower braces: Front (hit with high temp paint) [attach]213163[/attach] Rear (hit with trim paint) [attach]213164[/attach] As much as I love chrome and pink, I think it clashed with the current palette. Much needed upgrade to the ICE: Pioneer APH-P1400DVD head unit (awesome deck with AM/FM/CD/DVD/iPod-iPhone-iPad integration) [attach]213165[/attach] |
1 Attachment(s)
Fun little mod I did a few weeks back.
Switched out the 1156 sockets for double contact 1157 sockets. Amber single filament stays illuminated with park lights and second filament illuminates with turn signal indicator. Something different. [attach]213162[/attach] |
| All times are GMT -7. The time now is 11:17 PM. |
