Over Stock of Parts
Former Sponsor
From: 865 A Sweetser Ave.Novato, CA (new shop smell too)
Car Info: MY04 STi some call it a race car
Over Stock of Parts
Including Install (Package Discount)
-APS Cold Air Intake (65/70mm):
$390 OTD
-Cusco Front and Rear Sway Bars + Whiteline Front and Rear Endlinks:
$690 OTD
-Cusco Front and Rear Sway Bars:
$440 OTD
-Goodridge SS Brake Lines (02-07, includes fluid):
$280 OTD
-Group-N Engine Mounts:
$240 OTD
-Group-N 5spd Mount:
$110 OTD
-Group-N 6spd Mount:
$110 OTD
-Kartboy Short Shifter + Bushings (5-spd):
$255 OTD
-Kartboy Short Shifter + Bushings (6-spd):
$310 OTD
-K'SAI Turbo Back Exhaust (Catted)
$1,480 OTD <-- includes dp gasket too
-K'SAI Turbo Back Exhaust (Non-Catted)
$1,385 OTD <-- includes dp gasket too
-Whiteline ALK + Bump Steer Kit:
$625 OTD
*requires alignment
-Whiteline ALK:
$320 OTD
*requires alignment
-Whiteline Bump Steer Kit:
$285 OTD
*requires alignment
-Whiteline Adj. Lateral Links (WRX Sedan):
$500 OTD
*requires alignment
-Whiteline Adj. Lateral Links (STi):
$500 OTD
*requires alignment
-Whiteline Heavy Duty 22-24mm Sway Bar Mounts (WRX/STi):
$165 OTD
-Whiteline Solid Rear Endlinks (WRX/STi):
$160 OTD
-Whiteline Solid Front Endlinks (WRX/RS):
$160 OTD
-Whiteline Spherical Rear Endlinks (STi):
$160 OTD
-Whiteline Spherical Front Endlinks (STi):
$160 OTD
Just Parts
$320 OTD
$635 OTD
$365 OTD
-Goodridge SS Brake Lines (02-07):
$135 OTD
$150 OTD
$85 OTD
$85 OTD
$170 OTD
$225 OTD
$1,370 OTD <-- includes dp gasket too
$1,260 OTD <-- includes dp gasket too
$450 OTD
-Whiteline ALK:
$245 OTD
$200 OTD
$425 OTD
$425 OTD
$130 OTD
$130 OTD
$130 OTD
$130 OTD
$130 OTD
ALSO ALWAYS IN STOCK:
-AXXIS Brake Pads (all years & models)
-HAWK Brake Pads (all years & models)
-CENTRIC Rotors
-STOPTECH Rotors
-DBA Rotors
-GOODRIDGE Brake Lines
-COSWORTH Head Gaskets
-GFB BOV
-CUSCO Strut Tower Bars
-SWIFT Springs
-KYB AGX
-KYB GR2
-COBB AP v2
-Walbro Fuel Pumps
-Prodrive 3 Port Boost Solenoid
-DeatschWerks Injectors
-WHITELINE Products
-Steering Rack Bushings
-Rear Diff Bushings
-Subframe bolts
DID YOU KNOW...?
That we also stock every gasket & seal for your car including:
-Wheel Bearings
-All Filters
-Spark Plugs (1 step colder as well)
-OEM Clutches
*offer good until August 31, 2008...AND everything listed is in stock!
-Noah
$390 OTD
$690 OTD
$440 OTD
$280 OTD
$240 OTD
$110 OTD
$110 OTD
$255 OTD
$310 OTD
$625 OTD
*requires alignment
-Whiteline ALK:
$320 OTD
*requires alignment
$285 OTD
*requires alignment
$500 OTD
*requires alignment
$500 OTD
*requires alignment
$165 OTD
$160 OTD
$160 OTD
$160 OTD
$160 OTD
Just Parts
$320 OTD
$635 OTD
$365 OTD
$135 OTD
$150 OTD
$85 OTD
$85 OTD
$170 OTD
$225 OTD
$450 OTD
-Whiteline ALK:
$245 OTD
$200 OTD
$425 OTD
$425 OTD
$130 OTD
$130 OTD
$130 OTD
$130 OTD
$130 OTD
-CENTRIC Rotors
-STOPTECH Rotors
-DBA Rotors
-GFB BOV
-SWIFT Springs
-KYB AGX
-KYB GR2
-COBB AP v2
-Walbro Fuel Pumps
-WHITELINE Products
-Rear Diff Bushings
-Subframe bolts
DID YOU KNOW...?
-Wheel Bearings
-All Filters
-OEM Clutches
-Noah
stirs
Oct 28, 2010 11:54 PM
