Side mirror replacement, 1998 legacy?
Old Aug 18, 2006 | 04:44 AM
pyrilium's Avatar
Car Info: 1998 Legacy/Outback
Question Side mirror replacement, 1998 legacy?
Hey folks,
Someone sideswiped my parked legacy recently and took off the driver's side mirror - housing and internals mounts pretty badly damaged - and I'm looking for information on how to remove the mirror from my door so that I can repair or replace it. I'm guessing I have to pull the door panel in addition to the tweeters, but not sure exactly what to do. Anyone else had to do this, or have info they can share with me?
thanks,
p
Old Aug 27, 2006 | 12:51 PM
emyselfandi's Avatar
the black tweeder cover should just pull off. the door panel is held on by 3 or 4 bolts. pull those bolts and pull the door panel off. The mirror is held on by another 3 or so bolts. Unscrew those and disconned the wire harness (if you have power/heated mirrors). bolt the new one up and connect the harness. turn car on and test mirror. If it works shut the car off and re assemble the door trim. it's an easy job.
Old Sep 26, 2006 | 11:44 PM
thesnowboarder's Avatar
Car Info: 1990 turbo miata
it the nail on the head, sounds exactly as i would have put it
zavier
Jan 19, 2007 08:37 AM
vw_wrx
Nov 6, 2005 02:16 PM
AWD 20T
Feb 15, 2005 10:49 PM
Rat
Feb 26, 2004 03:49 PM
sampson
Jan 8, 2004 03:05 PM
