over heating ..need help with diagnosing
Old Sep 26, 2012 | 06:21 PM
pantyraid's Avatar
Car Info: 1997 gc8 wrx 4dr
I think I figured it out but thought I should ask here.
I got a great deal on my 98 gt because the kid said the water pump was out..
upon inspection I noticed the water neck was leaking profusely" well the kid took the thermostat out because he heard he could get more HP"
well in doing so he stripped the bolts and tried to use a paper gasket and lock washers..
I replaced the neck, tstat and bolts ..rtv sealed and thread locked everything and she was still over heating slowly.
I took the radiator apart and cleaned it as well as replaced the hoses..
was told could be head gasket... I did a compression test and I'm getting 185-200 in all cylinders ...
I thought could be the heater core so I unplugged both line and sure enuf no pressure coming into the motor but plenty coming out" water pump is still good right?
tomorrow I'm going to bypass the heater core and see if that helps...
could it still be a head gasket even though I'm not loosing any pressure ?
Posted from I-club.com App for Android
Old Sep 26, 2012 | 06:27 PM
Heedz's Avatar
Nobody likes the tuna here
any coolant in your oil? vice versa?
Old Sep 26, 2012 | 06:46 PM
pantyraid's Avatar
nope none..its clean..I flushed the motor and the radiator and no sighn
Old Sep 26, 2012 | 06:49 PM
xGT LEGOx's Avatar
Car Info: LEGACY L7 BD,GF8 WAGON
most likely the headgaskets are bad,same thing happened with mine.
Old Sep 26, 2012 | 08:04 PM
pantyraid's Avatar
so even if the head gaskets are bad I won't loose any compression?
Old Sep 26, 2012 | 08:10 PM
strider327's Avatar
Car Info: 2005 WRX
Its either 3 things: Your themostat is going, you have air bubbles in your cooling system or your headgasket is done.
Old Sep 27, 2012 | 01:53 AM
pantyraid's Avatar
that's what I don't get ...if my head gasket is done I should loose compression right? or at least have mixtures ...could it just be a clogged heater core
Old Sep 27, 2012 | 11:58 AM
pantyraid's Avatar
bypassed the heater core and that fixed the problem...but now its smoking like crazy but I think its excess moisture burning off the heat shield
Old Sep 28, 2012 | 11:49 PM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
just wait a couple of days and you should be fine
onthewater
Aug 12, 2012 09:38 AM
zaksti
Oct 19, 2010 02:32 PM
scapy2
Aug 2, 2004 01:54 PM
silvrwrx
Oct 27, 2003 01:18 PM
waren
Mar 19, 2003 10:41 PM
