HELP! Car over heating!!!
Old Sep 21, 2010 | 10:17 PM
zaksti's Avatar
Car Info: subaru sti
So my 05 STi has been down for 2 years. I sold everything under the hood so I needed a whole swap to get it running again. I bought a full engine swap from a 04 STi with 71k and dropped it in. When filling the radiator coolant it started leaking through the block so I ended up changing the water pump, timing belt, tensioners etc...I used a Gates OEM timing belt and water pump kit. Oh when I took out the water pump I noticed the blades were rubbing against the block? Anyways I drove the car around for a couple days with no problems. The next day I needed to drive from L.A. to S.F. and about half way (3 hours) I noticed on my Defi gauges the water temperature rose to 220* so I pulled over to let it cool. After that I drove the rest of the way (3 hours) with the heat full blast and it didnt go over 190*, but when I got off the freeway it started to over heat again! It went up to 230-235* this time around! The only thing I thought of was the thermostat being bad. I changed the thermostat with an OEM one and it still over heats after 30 minutes from a cold start. The idle starts to go all crazy too when this happens. Everything else seems perfectly fine. Any thoughts? Thanks in advance for any help.
Old Sep 22, 2010 | 03:24 PM
zaksti's Avatar
anyone please?
Old Sep 22, 2010 | 03:33 PM
johndabrit's Avatar
Da Brit.
could be as simple as airlock and you need to burp it out really well. Could be a bunk thermo. You drove on it a long time. You might have cooked it which will require machine work to true it out again.
Old Sep 22, 2010 | 03:49 PM
zaksti's Avatar
i burped it twice. once when i put the new thermostat in and once 15mins later. the new thermostat only has 30mins driving on it...sorry when u say "cooked it" what are u referring to?
Old Sep 22, 2010 | 03:56 PM
johndabrit's Avatar
Da Brit.
i just mean if you drove on it while it was hot, or if it reached a high temp, it could be warped. Temperature abuse is a futher mucker.
Old Sep 22, 2010 | 04:22 PM
I was going to say air bubble bleed it on an incline but thats been covered. Try running it with out the thermostat see if it over heats then
Old Sep 22, 2010 | 04:30 PM
Did you flush the radiator?
Old Sep 22, 2010 | 04:32 PM
are both radiator hoses hot when you over heat?
do they both have pressure?
Old Sep 22, 2010 | 04:33 PM
zaksti's Avatar
like the block can be owned?
Old Sep 22, 2010 | 04:34 PM
zaksti's Avatar
ive change the fluid 3 times but i didn't use pressure to flush it out. i just emptied it and but new fluid.
Old Sep 22, 2010 | 04:35 PM
zaksti's Avatar
i believe so but i can double check. if they are? and if not?
Old Sep 22, 2010 | 06:18 PM
FW Motorsports's Avatar
iClub Silver Vendor
Car Info: 2005 LGT wagon
You're ****ed.
The head gaskets are done, the block is most likely scrap.
Old Sep 22, 2010 | 06:29 PM
zaksti's Avatar
You're ****ed.
i don't think its that bad. ive blown a head gasket before and the car smokes like crazy. no smoke here at all.
Old Oct 19, 2010 | 02:32 PM
Evil imports's Avatar
Car Info: 04 STI and 02/04 STI wagon
Did you make sure you got the right part number for the gates water pump?? it shouldn't be hitting the block, maybe they sent you a wrx one as the 02-04 wrx have a different pump they 04-07 sti, i would think maybe if you said it was hitting the block, maybe it could have got caught and not spin correctly
pantyraid
Sep 28, 2012 11:49 PM
onthewater
Aug 12, 2012 09:38 AM
scapy2
Aug 2, 2004 01:54 PM
silvrwrx
Oct 27, 2003 01:18 PM
waren
Mar 19, 2003 10:41 PM
Top
