Newbie needs info & help
Old Feb 3, 2004 | 04:57 PM
nuburu2's Avatar
Car Info: 98 GT Wagon
OK, OK, Lots of views, no reply because most of these have been dealt with time and again, but since you're a Noob, I'll try to help.
1)Foglight button should be backlit and light a different color when switched on. Bulbs are just like HVAC mini-lights and install from the side of the button after you pry it out gently with a screwdriver. They don't work? I'd look at fuses/connections after checking owners manual.
2) HVAC lights do light as well as show which is selected. Look here; http://www.scoobymods.com/
3) Depending on whether you hear the motor operating when the radio is switched on/off it could be fuse/motor/toothed "stiffener" inside the mast is broken.
4) WD40
5) Vibrating heatshield on exhaust.
6) Design problem, but the lenses also age and discolor and can be cleaned and polished with polishing compound/Brasso/Toothpaste/Novus plastic polish etc. DON'T just throw in some hi-watt bulbs or you'll fry the harness. I installed a HD Harness with bigger gauge wire and relays to gain some output, but don't expect miracles.
7) See the dealer, or post in WTB forums. Enough owners ***** about woodgrain and may want to get rid of woodgrain.
Glenn O
Old Feb 28, 2004 | 08:17 PM
dugrant153's Avatar
Car Info: 1985 Corolla AE82 FWD
just how common is it?
Old Feb 28, 2004 | 09:55 PM
Nick Koan's Avatar
Car Info: Legacy GT
For the DOHC 2.5L engines (which I'm about 99% sure your vehicle has), its actually more common then Subaru would probably like to admit.
Old Feb 28, 2004 | 10:47 PM
dugrant153's Avatar
Oh, I don't actually own one... yet
Why doesn't Subaru just admit it's a problem!
A recent poll on NASIOC I did (it's still there. Anyone is welcome to vote to make a more accurate measure) showed that out of 22 Impreza respondents, 25% of them had headgasket issues.
So yeah... I really don't know. I want to buy an Impreza, but I don't want to have to deal with a blown engine, especially if I buy an older car out of warranty. Suggestions anyone? I'm really desperate for answers but I'm just not finding any...
Blitzsileighty, congrats on your purchase I just drove a Subaru recently and I like it (it was an Impreza 2.2L, though).
ruins30
Apr 21, 2009 01:47 PM
blutes3
Nov 13, 2005 08:59 PM
CSUJeff
Oct 2, 2004 12:28 PM
VitaminWRX
Nov 1, 2003 12:58 AM
Mirko
Mar 12, 2003 05:07 AM
