I need a transmission expert
Old Jun 18, 2006 | 07:52 PM
mtb_medic's Avatar
Car Info: 1972 porsche 914
OK so here is the deal.... Is there some way that I can modify an overdrive automatic from a 1994 legacy JDM so that I can run it without the rear driveline attached????
I have heard that a transmission could have the differential welded.
any help would be greatly appreciated.
thanks
matt
Old Jun 19, 2006 | 10:49 AM
DLC's Avatar
DLC
Car Info: 2000 Leg GT LTD
You could just swap in a FWD transmission from a 92-94 Legacy, remove the driveline and rear differential, and replace the rear hubs with those from a FWD Legacy. That'd get you better fuel economy, acceleration in the dry, and whatever else you may be looking to accomplish with a welded differential.
Old Jun 19, 2006 | 10:45 PM
mtb_medic's Avatar
hey thanks for the reply. I have thought of that but it is my understanding that the fwd transmission cannot handle the same hp as awd trans. also I have already have the awd transmission.
will a welded diff work?
Old Jun 19, 2006 | 11:10 PM
mtb_medic's Avatar
I think that I finally get it. the awd transmission has a center differential. could I remove this differential and replace it with the gear that is installed in the fwd trans and then plug the drive line hole??
Old Jun 20, 2006 | 10:23 AM
DLC's Avatar
DLC
That sounds feasible, yes. There may be an Impreza owner that has done this, but I'm unaware of anyone who has. You may try contacting a few performance rebuilders, like IPT Performance ( http://www.importperformancetrans.com/subaruauto.shtml ), and asking them if it's possible.
-j-
Oct 28, 2005 12:21 PM
wes2603
Dec 13, 2004 12:28 PM
sonic_yellow
Jun 11, 2004 11:53 PM
