1991 legacy (help with loose shifter)
Old Oct 26, 2006 | 08:23 AM
Jbar3987's Avatar
Car Info: 1991 Legacy Wagon
I have a 1991 legacy with a very loose shifer.
Anyone know to fix this problem? New shifter bushings?
Know where to get them?
Thanks!
Old Oct 26, 2006 | 09:09 AM
Yes, bushings should definitely help that problem. Unfortunately, I know little about early Legacies, so unless they share shifter parts with early Imprezas, you'll have to dig to find some bushings for it. There may not be any "name brand" bushings like Kartboy, but I guarantee that SuperPro or Energy Suspension or somebody will have them available if you know where to look. People have been rallying those cars way too long not to have urethane everything available somewhere.
Old Oct 26, 2006 | 09:15 AM
Jbar3987's Avatar
Thanks for the response. I tried both SuprePro and Energy Suspension, to no avail.
Energy doesn't even list legacy's...
Old Oct 26, 2006 | 01:23 PM
DLC's Avatar
DLC
Car Info: 2000 Leg GT LTD
There's a spring in there that can fail and pop out, leaving the shifter unable to return to center. It's a few bucks at the dealer, and tricky to install but not impossible.
If it's just sloppy, consider a newer WRX/RS/Legacy linkage from someone who has upgraded to the STi shortshift. You'll need the whole assembly, plus one additional part from the dealer, but all short shifters and bushings will fit it. It's pretty much the only way to improve the shifter feel above OE.
Old Oct 27, 2006 | 08:41 AM
Jbar3987's Avatar
Well, I am just really looking to bring it up to OE feel, but if an upgrade is only a small amount more I'm all for it.
BTW does anyone ahve a link to an install on just the bushings alone?
Old Nov 23, 2006 | 05:56 PM
Kay95's Avatar
I had a 90 legacy. The normal kartboy, superpro what ever for a impreza will fit. Both the front and back bushings. That most likely isnt the problem. You have to get under the car. You will see what looks like a U joint. There are 4 bushings in there. Replace them that WILL fix the problems.
22B05STI
May 17, 2023 09:07 AM
Marit
Nov 5, 2021 07:18 PM
Marit
Cars For Sale
Jul 26, 2006 11:52 AM
nico posteraro
Mar 13, 2003 08:07 AM
subyfanatic
Mar 3, 2003 02:38 PM
