HELP: HID lighting connection issue
Old Aug 23, 2010 | 03:54 PM
addicted2jayz's Avatar
Car Info: 11 WRX Hatch
i juss bought and HID kit for my 2000 impreza and its a plug and play kit, i plugged in all the wires to the ballast and plugged in the HID socket to the original socket and its not powering my HID bulb, its only powering the low beam light.
how can i get the HID bulb to light instead of the low beam light?
Old Aug 23, 2010 | 04:23 PM
DarkJuic3b0x's Avatar
Car Info: EQ Tuned * Corn Juiced '05 WRX
It's not quite plug and play, atleast it wasn't for me since I have a set of halo/led projectors. I had to splice a few wires but ended up using the OEM harness connectors (gray ones).
What's your set up like? OEM headlight assembly?
Can you post some pictures up of your HID assembly? How you connected everything? That'd help alot!
Old Aug 23, 2010 | 04:41 PM
hers the kit i got
hers how i connected them
Old Aug 23, 2010 | 07:02 PM
nvm i got it to work, i juss switched some wires around.
now im figuring out how to aim the lights so they're even, anyone know how?
Old Aug 24, 2010 | 05:41 AM
Pearl07STI's Avatar
Car Info: 2015 FXT
yea i had the same problems with installing my g/fs HID fog lights... they wouldn't turn on and then I messed with the wires some more and now they work perfect.
Old Aug 24, 2010 | 03:33 PM
Good, I'm glad you got them to work. I'm not sure how the impreza headlights work, but usually there is a screw or two near the bottom of the headlight assembly that controls the aim of the headlights. Try that out and see if it works
Old Aug 24, 2010 | 03:41 PM
^^^yeah i saw only one screw at the bottom, didnt know if it was to aim the lights or unscrew the headlamp. but ill try to mess with the bottom screw and see what happens
Old Nov 11, 2010 | 04:09 PM
mmagic's Avatar
Car Info: '21 Ascent Touring
anyone want to shed some light on why they run the wires the way they do through that grommet? you would think the end that goes into the oem plug to be on the other side of the grommet and not the same side as the bulb, right?
Old Nov 11, 2010 | 04:31 PM
SolSurferX's Avatar
Car Info: 2008 specB
^No, because otherwise that connection would be exposed to the weather. You don't want water on that connection.
Keoks
Mar 11, 2015 05:33 PM
kyoung05
Jan 31, 2010 11:40 AM
babymike
Mar 8, 2009 04:17 PM
JRsWRX
Dec 2, 2006 04:04 PM
kennyvb
Jun 15, 2005 03:25 PM
