NEED HELP! Crank no start
Old Sep 24, 2012 | 05:30 PM
Zanderson's Avatar
Car Info: 05 Impreza
2005 Impreza NA EJ25 recently replaced motor. So I have no RPM signal via scan tool and no codes. Checked CKP wiring and the sensor its self, all good. Back probed ECM connector and had signal there while cranking, but no signal out to ignition coil. Really lost and could use any helpful advice.
Old Sep 24, 2012 | 06:03 PM
JesseConant's Avatar
Car Info: subaru XV
You may try starting it with starting fluid. I had a friend of mines FICM give out in Houston at 2K12 and we were able to get it started with starting fluid to get us back to corpus.
Old Sep 24, 2012 | 06:30 PM
Zanderson's Avatar
I wish it were that easy, but it has fuel just no spark. Im thinking its the ECM but I have never heard of an ECM going bad in just one area like that. It still communicates with my scan tool and has crank signal just not recognizing it.
Old Sep 24, 2012 | 07:15 PM
Car Info: subaru XV
If you have no codes, then try priming your fuel system. I'd guess yours is sucking air.
Old Sep 24, 2012 | 08:04 PM
qingshan's Avatar
Car Info: '06 CGM Fo/12 SWP Sti
some connector is loose is my $0.02
Hope you get it going but as you figured out - it's ignition related
jakejacobs91
Jan 12, 2013 01:14 PM
Soobie22
Jul 8, 2005 03:48 AM
Scoober02
Nov 24, 2004 03:25 PM
Ka24de
Jul 20, 2004 09:32 AM
KnightRider
Dec 31, 2002 04:24 PM
