ignition power source
Old Aug 25, 2008 | 11:35 AM
kronizer's Avatar
Car Info: 87 mk3 supra
To pass canadian inspections i need to install daytime runningn lights and all i need to complete this is a signal - any power source that is on when car is running but not on when just the key is on. the instructions say wrap around the spark plug wire but i think there should be an easier way. the wire is long enough to reach across the engine bay, the module is mounted next to the battery. the car is 2005 wrx. thanks
Some examples as per the shotty instructions : oil pressure switch or a high point 12v source when ignition is in run position
Old Aug 25, 2008 | 02:13 PM
jinorazi's Avatar
Car Info: 05 cgm imp
oh thats a tough one...power only when car is running. -,.- that beats me.
i'd say make your life easier and just hook it up to ignition. grab it from the steering column wiring harness or fuse box which would be easier.
Old Aug 25, 2008 | 02:14 PM
wrxisthebest's Avatar
cigarette lighter
Old Aug 25, 2008 | 02:38 PM
jinorazi's Avatar
Originally Posted by wrxisthebest
cigarette lighter
power only when the car is running.
cigarette lighter would either be constant or ignition (key on acc. or ign. position).
Old Aug 25, 2008 | 03:43 PM
kronizer's Avatar
ya that was my thinking, i was trying to avoid going thru the fire wall if i didnt have to.
anyone else know something? where the oilpressure switch is or if its accessable? seems like a simple thing but its being far from
Old Aug 25, 2008 | 06:33 PM
jinorazi's Avatar
if its like trying to install a oil pressure gauge, i hear its a pain in the ***.
i'd say just put it to your ignition switch, i dont remember off head if there is a fusebox inside the engine bay but if there is, just find any acc or ign source, if not, just run it inside the car via gromet so you dont have to drill a hole. either way you can wireloom it and such so it looks stock.
Old Aug 26, 2008 | 07:31 AM
kronizer's Avatar
foudn out the windshield wiper fluid motor has a power source key on. thanks alot for the help and suggestions
Subi_life
Jan 25, 2014 07:38 PM
Subi_life
Jan 24, 2014 08:15 PM
blkwagon
Sep 24, 2012 12:28 AM
ziggydikface
Aug 9, 2004 11:07 AM
Salty
Feb 2, 2004 04:06 PM
