HOW TO REMOVE SEAT BELT BEEPING NOISE ,DAY LIGHT SAVING LIGHTS, and watever that ..
ok.... there are 2 different ways to do this, and also 06 and 07 DRL Disable mods are DIFFERENT!!!!! (Read again: DIFFERENT!)
06 = DRL modual behind glove box
07 = NO DRL modual behind glove box (but a different relay that controls DRL/Headlights, simple one wire removal to disable DRL's!)
Edit: your a moron if you unplug the silver box under the hood (read: drop voltage resistor). if you take your subie in to the dealer and they see it, bye bye warrenty! with the 'behind glove box' mod, they have to tear into your dash in order to see it!
how to remove the beep noise from seatbelt
turn your key to ON, (the step before you turn on your engine)
buckle up your seatbelt on and off for 20 times with in 30 seconds, your beep sound will be gone the next time your turn on your car. it will beep only once when you start the car, and will never come back up.
to remove this setting, just disconnect your battery
i still havent found how to remove dLr =(
Car Info: WRX --> RX-8--〉E93
search on nasicbo or scoobymods they will have one. your car is 07 im thought its the same thing as 06, if is 06 its really easy. you dont even have to take the glove compartment off.
let me look for it
let me look for it
Car Info: '02 WRX wagon
welps i need help period. cant find it still
you aint my mommy.
yes, yes it was.
Anyways, the silver module way works for the lights. For the seatbelt.....buckle your seatbelt. For the louder turbo sound, remove the silencer/snorkle/resonator from the passenger side front fender.
searches:
-seat belt chime: https://www.i-club.com/forums/search...archid=1111809
-intake silencer: https://www.i-club.com/forums/search...archid=1111811
-daytime running lights: https://www.i-club.com/forums/search...archid=1111814
searches:
Heedz
Mar 15, 2015 04:32 PM
swackerl
Sep 17, 2006 04:07 AM
Salty
Sep 7, 2005 02:39 PM
