Need Help Figuring this out
Old Aug 14, 2007 | 10:59 AM
i-max's Avatar
See my post re: Car running bad after UP & DP install:
http://forums.nasioc.com/forums/show...1#post19042971
Old Aug 14, 2007 | 11:47 AM
iNfEk's Avatar
i replied
Old Aug 14, 2007 | 11:59 AM
Island Style's Avatar
Hey Bob,
yeah, as it was said on NASIOC...your problem will mostly likely go away by reflashing your AP with the STG2 map...
you need to go to the Cobb site and download the Stg2 basemap and real time maps for your year WRX.
You will find a base map, HWG (high waste gate), LWG, valet, anti-theft, etc.
Make sure you download for your particular car and for 91Octane...do not use the california or 93 oct maps.
Now you have to go through the procedure of taking off the basemap by plugging the green connectors under the dash, connecting the AP to your car...and following the instructions to remove the base map from the ECU...
Once this is done, you can remove the maps off the AP by connecting it to your computer using the serial cable and using the Cobb Map Manager software...remove them, save them somewhere, upload your new maps into your AP, then install the new Stage2 base map on your ECU...once again following the instructions to install the basemap...should take from 10min - 30min...
Don' forget to unplug the green connectors after you flash in the basemap!!!
Once your new Stg2 base map is installed, you can flash in your real time maps as usual...if you are having a difficult time hitting your target boost still, you can use the HWG map...
Old Aug 14, 2007 | 08:36 PM
i-max's Avatar
Hey Brent,
Ok...I guess going to Stage 2 is the answer. I didn't think that changing out the uppipe would make a lot of difference in the driveability of the car. I'll take your advice and download the map you described then proceed to install the map. Like I said, I've been running a DP and Borla for the longest time and no problems... was I lucky! Thanks again.
Old Aug 14, 2007 | 11:34 PM
Give it a shot...
yeah, you should have been at stage 2 a while back with your dp/catback and filter...
You'll notice your boost comes on faster with the Stage 2...although, the downloadable Cobb maps are very conservative...
If you were to buy an over the counter protune map for your car from PDXtuning.com for example...you will find even greater joy...not only will your boost come on faster than the ordinary stage two maps...you will hold the boost longer throughout your powerband...several of us here are true believers in the PDX maps we received.
Old Aug 15, 2007 | 10:28 AM
i-max's Avatar
Thanks to all... I resolved most or all of my driveability concerns... I reset my computer. Now for the Stage 2 download this weekend.
chinhator
Jun 11, 2014 01:40 PM
w0ng3r
Jan 18, 2014 02:43 PM
2002 WRX
Aug 20, 2010 09:14 PM
Alliedforces86
Jun 29, 2010 05:50 PM
WickedSpeed
Mar 3, 2004 10:13 AM
