Need help with 03 wrx problem..
Old Jul 16, 2011 | 10:33 PM
Slick808's Avatar
Car Info: 03 subaru wrx wagon
03 wrx wagon prob FIXED!!!!!
Ok so it's being a while since I been working on my car and trying to get it to run good...but now it's getting to a point when I have no idea what's wrong with the car already...so I'm posting this hoping to find someone with more knowalge about this engine and give me pointer or possibly help me with this..I love this car and I really want to keep and bring it back to life again...thanx u all!
Pm is good but call or text would be nice my name is shota
(808)783-6569 thanx again
UPDATE!
The car is running good now! It was the tgv sensor that was bad
Thanx all for the help!!
Old Jul 17, 2011 | 12:27 AM
Solhaboy187's Avatar
Car Info: 2008 Impreza STI, 2005 Forester XT
whats are the symptoms?
Old Jul 17, 2011 | 02:51 AM
iNfEk's Avatar
exactly what's the trouble?
Old Jul 18, 2011 | 02:01 AM
Slick808's Avatar
Ok so the set up I have is ej20 with vf39,Sti injector, up pipe, full exaust, fuel pump...stock ecu with no tune yet...I'm hoping that is it just the tune but my car don't pull like it used to be and when I had bov it was surging after like 5 pound of boost..so I put the stock bpv without recurcling and the surging is gone..other then that there's I believe oil leak..coolant leak..and I believe power staring fluid leak from god knows where...the car is just pretty much running like crap...but no smoke coming out of exhaust..also my af is reading really weird coming to stop and I idle at the 15.0...and on and on..just trying to fix one by one...
Old Jul 18, 2011 | 02:02 AM
04sleeper's Avatar
problem solved
Old Jul 18, 2011 | 02:59 AM
YuudaiSTI's Avatar
Car Info: 57 SM 04 STi, 04 Yamaha R6
^ Tune will definitely help. I'd also fix all your small issues to get all that out of the way, simple maintenance will go a long way. You also said you have the stock BPV on without recirculating? Do you have the recirc hose plugged? Having a giant hole after your MAF will make everything run like crap. Either way, I'd fix all the little crap and take it easy til you can get a tune.
Old Jul 18, 2011 | 03:34 AM
Slick808's Avatar
I just don't want to spend that money for tune and find out that it's not tunable...so trying to make sure everything els is ok and that its just runnin bad cause of no tune..not bad compression or bad turbo...and yes it's plugged..also I would like to fix those leaks but have no Idea where it's coming from...it's hard to explain but it looks like it's coming from above up pipe by the header..that's what it look like..should I just do like leak down test? If so dose anyone kno how or done it before? How much? Thanx
Old Jul 18, 2011 | 08:41 AM
J.J's Avatar
J.J
Car Info: 2003 subaru impreza wrx wagon
you slick808 i have the same problem before ! more worse i think !! hit me up i got the tools to check a leak ! and some xtra parts for ej20 txt me 808 253 8871
hit me up may be i can help you !!!
Old Jul 18, 2011 | 12:41 PM
shaggadelic's Avatar
have you checked your valve cover gaskets? that could be the oil leak on the sides.
Old Jul 18, 2011 | 01:27 PM
Slick808's Avatar
No I haven't check that...where is it and how do I change that?
Old Jul 18, 2011 | 01:37 PM
toogood131's Avatar
Car Info: 2003 WRX sedan
Under the valve covers
Seriously though, check this thread
https://www.i-club.com/forums/hawaii...gasket-231923/
Old Jul 18, 2011 | 01:56 PM
Slick808's Avatar
Man that looks like pain in the *** to get to...oh yeah just found out that boots for te power staring thing by the axil...maybe that's where the splash by up pipe is coming from..??
Old Jul 18, 2011 | 02:02 PM
Slick808's Avatar
Sry the boot is bust
Old Jul 18, 2011 | 02:25 PM
toogood131's Avatar
It is a pain. If you do decide to check them, I'd recommend removing the battery, window washer reservoir and intake.
Had a guy selling the boots for super cheap on cl/fh, but I think he sold them I cannot find the ads
Old Jul 18, 2011 | 03:28 PM
YuudaiSTI's Avatar
It isnt that hard.
