HELP! Check Engine Light
Old Jan 6, 2010 | 11:43 AM
SubieJunkie>_<'s Avatar
From: Kalihi by Day, Waipahu by Night "808 ALL DAY"
Car Info: BLK on GOLD '06 WRX [S_JUNKY]
well i was on my way home from ala moana driving on the freeway using cruise control then all of a sudden i felt my car starting to slow down and i looked i seen my check engine light is on and at the same time the cruise control light is blinking. what can be the problem? need help. any suggestions on what it could be?:
Old Jan 6, 2010 | 12:24 PM
HISTATEOFMIND's Avatar
Car Info: hard in the paint!!!
hard to tell but if you can get hold of an OBD scanner, it will tell you what's wrong on spot. could be a lot of things na mean?
Old Jan 6, 2010 | 12:47 PM
Haole-Pino's Avatar
I've encountered the same problum. In my case, I threw a "P0171 -System too lean" code (To much spirited driving, and short shifting...15mins later the code popped up). When a code is thrown, it disables your cruise control making it temporary inoperable untill the code is removed. Which would explane why your car began to slow down. The cruise control light flashing, and check engine light remaining on, is just a way the car indacates to the driver that a code has been tripped. If you are currently using a Accessport, just plug it in. Remove the codes, and reflash your real time map. If your not using an accessport, plug in a diagnostic OBD scanner, like HISTATEOFMIND suggested, and remove the code.
Old Jan 6, 2010 | 07:12 PM
Thanks HISTATEOFMIND & Haole-Pino for the heads up. im new to these things n ill call up some of the guys with more experience to take a look at it.
Thanks again guys
Old Jan 6, 2010 | 09:42 PM
BattleD01's Avatar
From: battling between the mountain munstas! Kalihi
Car Info: GC8 Type-R, BH5 Wangon Gen3 and 05 SV650 Naked!
I know what it is Ed, but your thinking to much cosmetics then performance thats why your girl is acting up on you suka.
Old Jan 6, 2010 | 10:19 PM
Thug Nasty's Avatar
Car Info: Hi, I'm John.
You actually use your cruise control on H1?
Old Jan 6, 2010 | 10:40 PM
performance meaning flowmasters on a subaru? Hmm...LOL!
sad but true
Old Jan 6, 2010 | 10:44 PM
BattleD01's Avatar
no like that CS lip I help you install.... when you should have bought a new Y pipe! LOL.... nah it could be anything just scan it and see what pops up.
Old Jan 6, 2010 | 10:47 PM
BattleD01's Avatar
whats that cruise control? thats for lazy people or scared they might go over the speed limit or if your drunk LOL. JPA
Old Jan 6, 2010 | 11:00 PM
yeah like drunk driving. it helped me out 2 in the morning going home drunk from kalihi to waipahu. if not im gonna end up like those guys on Shaggs thread. LOL!
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
The Works
Dec 30, 2002 08:53 PM
