Check engine light and abs
Old Jun 17, 2013 | 02:34 PM
jetro12's Avatar
Car Info: 2013 Subaru WRX STI
So i stated my car and the check light and the cruise control light was on and the letter S for spirts mode was on. I brought it in and they said the gas cap wasnt tightend so they cleared the code at the dealer. Now the abs light turned on this morning so as the traction control light for about 10 mins while driving. I parked turned off the engine and turned it back on and it went back to normal. Should I bring it back to the dealer anyways even though its back to normal?? What would cause that to turn on by itself?? Thanks for the input. I have a 2013 STI with 5209 miles in it.
Old Jun 17, 2013 | 02:54 PM
Harry Maneuvers's Avatar
Car Info: 04 WRX Wagon, 06 Forester XT, 99 Legacy Sedan
ABS and Traction control lights are tied to eachother.
If either of those two systems detects a fault, they will both be illuminated which indicates that they are both disabled (at least that is the case with the ABS light).
I dont think the two things are related. Your CEL and cruise will illuminate if the gas cap is not on tight but those have nothing to do with the ABS and/or traction control.
I would take a look at each ABS sensor by the HUB and check to make sure that they are in tact and free of debris.
Old Jun 17, 2013 | 06:20 PM
04sleeper's Avatar
call a priest to exorcize the ghosts. nothing worse than a possessed car
Old Jun 17, 2013 | 06:22 PM
04sleeper's Avatar
no but really if you don't have a code now just wait and see if it comes back. if it does then you should get the code read. when you fill up make sure you turn it at least 1/2 turn after it starts clicking.
Old Jun 17, 2013 | 06:23 PM
ccalsubi's Avatar
Car Info: 2008 subaru impreza 2.5i
That happened to my car 3 days ago. It was a blown fuse for the rear lights. Check to see if your brake lights work.
Old Jun 18, 2013 | 08:58 AM
jetro12's Avatar
Thanks for the inputs
Racerkid
May 29, 2012 06:16 PM
VIBEELEVEN
Jan 22, 2011 04:18 PM
sadc
Jan 21, 2010 11:41 PM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
