General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
HID help
Old Apr 2, 2009 | 11:18 PM
thaSicness's Avatar
Car Info: Subaru WRX 08
Question HID help
Hey guys,
So im thinking about gettin' some HID's but I have no clue about bulbs and colors.
I know I want to get a good ballast and harness. Any recommendations?
Should I get 8000k? Or is that too much?
And when you get a HID kit does it only include the low beam bulbs? or high as well?
I hope somebody out there can answer all my questions
Thanks in advance!
Old Apr 2, 2009 | 11:33 PM
thaSicness's Avatar
http://www.fastwrx.com/coledtusibu.html
If i got these hyper white changing LED's which HID's would go well you think? 8000k?
Old Apr 2, 2009 | 11:47 PM
gottaWRX's Avatar
Car Info: toaster
I think 8k is too blue. Takes away visibility. But if you like it get em'..... I have 6k and i think those are too blue!
Wes
Old Apr 3, 2009 | 12:35 AM
thaSicness's Avatar
Wes
Yeah im leaning more towards 6k
Old Apr 3, 2009 | 12:39 AM
thaSicness's Avatar
Wes
Can I get something like.. for example;
PIAA 4100k Intense White bulbs non HID without the ballast?
Old Apr 3, 2009 | 12:52 AM
gottaWRX's Avatar
Car Info: toaster
Is it goin on your 08wrx? If that's the case then i believe they already have some type of projector housing so getting hid's with a ballast would be ideal for better output. PIAA is a great brand but kinda pricey.... If i were you i'd just get a hid kit for now if you're tryin to save $.... ddm kits are great and very cheap. i've had mine for 6 months and have had no problems whatsoever with a lifetime warranty on it. hope this helps.....
Wes
Old Apr 3, 2009 | 12:58 AM
thaSicness's Avatar
Wes
Yeah its for my 08.
Makes sense.
If I dont want HID if i simply just want 6k and diff color, i just have to make sure its the same watt as stock right? Which i believe is about 55watt
Thanks alot wes
Old Apr 3, 2009 | 09:12 AM
i say for that money just spend a bit more and buy the HID kit
Old Apr 3, 2009 | 06:51 PM
thaSicness's Avatar
Yeah I added up the money I'd spend on the bulbs and HID seems the way to go.
Any suggestions or links ?
Old Apr 3, 2009 | 06:58 PM
ScoobySon's Avatar
Car Info: 2006 WRX STI
If I remember correctly,
Silverstars use > 55W, and they are safe
The PIAA Plasma's say 55W -> 110W, but I think that just means their brightness or lumans are as bright as 110W $hitty bulbs.
Those are all the stock bulbs in the packing, btw.
All these fit MY09 but the HBs fit both HB3 & HB4. You just need to use the o-ring from the stock bulbs.
IMO, just save up for the HID kit...these bulbs are brighter than stock but HID's are on a whole other level.
Old Apr 3, 2009 | 07:10 PM
ScoobySon's Avatar
Here is some pics of the headlights with 3200K Highs and Lows. Don't be like me, GET HID Lamps.
W/ Flash
w/o Flash
Old Apr 3, 2009 | 07:15 PM
thaSicness's Avatar
^^^ looks good though man!
Thanks for the imput and the help
Have you seen the LED signal lights? They change from white to amber. pretty sick, and cheap!
Old Apr 3, 2009 | 07:20 PM
ScoobySon's Avatar
Ya, those look hella sick. Once, while a cop was writing my first speeding ticket in the wrx, he was asking about my lights and turn signals being illegal, but didn't give me a fix it ticket.
Old Apr 5, 2009 | 10:27 AM
wimprezax06's Avatar
Car Info: WRX --> RX-8--〉E93
6000k would be the best choice. looks a little nicer than oem 4300k but not as blue as 8000k which lowers the visibility.
Old Apr 11, 2009 | 05:24 PM
Daios's Avatar
Car Info: RIP: 2000 2.5RS Sedan, BRP Now: 08 WRB WRX Hatch
I have HIDs in my 08 from DDMTuning. works great. I actually have the 4500K ones, but 4500K-5000K should output the most lumens while anything higher gets into the blue/purple area and lose brightness. Simple install. I've installed the Raptor kit on numerous cars already with great results. If you want bright white I'd say 5000K is your best bet.
Heres the direct link to it:
http://www.ddmtuning.com/catalog/HID_Kits-85-1.html
wombatsauce
Feb 8, 2005 08:19 PM
qwk_wrx
Nov 10, 2004 11:20 AM
andivic
Jul 26, 2003 07:17 PM
suprawrx
May 24, 2003 09:27 PM
Cycloexane
Jan 10, 2003 01:22 AM
