General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
DIY: Protect your fog lights or fix your broken ones!
Old Jan 3, 2013 | 04:56 PM
BrendanTheGreat's Avatar
Car Info: 2011 WRX Sedan
So my OEM fog light housing cracked and there is really no way to truly repair it or get it replaced, so I came up with a somewhat solution. Actually its more of a solution to stop your fog lights from cracking. I know the make fog light protectors for the 08-10 STi and WRX but not for the newer body styles so here is what I came up with. Not the greatest DIY but its a straight forward job so I didn't go into too much detail. Enjoy!
Whats needed:
(1) Lexan Polycarbonate sheet 8"x10" .093in thick (basically plexiglass)
(1) Plastic cutter (I ended up using a Dremel)
Some super glue and or adhesive sealant.
Tape Measure
Tape
Safety Glasses
Patience
Close up of crack
Step 1
Remove your front bumper completely and remove fog light cover. This can be done carefully by prying it away from the bumper but to be safe and to not risk scratching I suggest taking the bumper off. Also I had to take out the entire fog light housing and hair dry it to dry up all the water inside.
Step 2
Cut your Lexan sheet. I originally planned to make a retangular piece and slide it in but clearance was smaller than I thought so I ended up cutting it down to size as seen in the second picture. I suggest making it a tiny bit bigger than the hole opening so you can glue it easily.
Step 3
Remove 1 side of the protective cover plastic piece covering the Lexan sheet. Place the side face down covering the hole so it faces out wards (into on coming traffic) when installed. Next take a two small pieces of tape and tape the Lexan piece into place, then glue either side. After a few minutes remove all of the tape and glue as much as you can. Let sit for a few minutes to dry.
Step 4
After the glue is dry carefully remove the last remaining protective cover so the Lexan sheet is nice and transparent. Then replace the fog light cover reinstall the bumper.
Completion
There good as new, or at least it will keep it new for longer than mind stayed new lol opcorn: This stuff is advertised to be 200 times stronger than glass and it has never failed me. I had this simple mod done to my old civic (common fog light crack problem) and it never cracked after that.
Attached Thumbnails DIY: Protect your fog lights or fix your broken ones!-8343263993_bd12793354_b.jpg   DIY: Protect your fog lights or fix your broken ones!-8344324370_a8e9d9c11a_b.jpg   DIY: Protect your fog lights or fix your broken ones!-8343263383_6583f345c2_b.jpg   DIY: Protect your fog lights or fix your broken ones!-8343262899_6442d79e12_b.jpg   DIY: Protect your fog lights or fix your broken ones!-8343262341_f3589af1d7_b.jpg
DIY: Protect your fog lights or fix your broken ones!-8344321424_f9157fb615_b.jpg   DIY: Protect your fog lights or fix your broken ones!-8343260945_56ca6d46a6_b.jpg   DIY: Protect your fog lights or fix your broken ones!-8343260483_f2ba470056_b.jpg   DIY: Protect your fog lights or fix your broken ones!-8343259929_fa38edc304_b.jpg
Old Jan 3, 2013 | 07:44 PM
theoutbackdream's Avatar
Car Info: 12Teens crazy 4 me
interesting! nice write up!
Old Feb 5, 2014 | 07:15 PM
BoostRetard's Avatar
Car Info: '13 WRX
+1
Any problems with the plastic getting too hot? No warpage or discoloration?
Old Feb 5, 2014 | 07:51 PM
Blazingbuda40's Avatar
Car Info: 2004 Forester XT
nice DIY
Old Feb 5, 2014 | 08:58 PM
Originally Posted by BoostRetard
+1
nope ive had it done since i did the write up and it works amazingly lol and you can barely notice them
Old Feb 5, 2014 | 09:14 PM
TheFozz's Avatar
Run a template over to TAP and ask them to do a small run for ya and then sell 'em.
WIN+PROFIT.
Old Feb 7, 2014 | 02:00 PM
04GG's Avatar
If in doubt, FLAT OUT
Nice work and great idea but seems like a whole lot of work for something that is going to fade and chip over time (except it won't be your lights getting damaged). You can get lamin-x sheets for a like $10 and not have to remove or glue anything. It looks like they don't make the precut ones for the 06-07s anymore.
Old Feb 7, 2014 | 02:10 PM
i<3dirt's Avatar
Dirty Purple Ukrainian
Car Info: SUBARU BROOM
I would really recommend getting fog lights protectors, i had to replace my fog light and it was $300. I just got some from my dealership for $35. this is a great DIY project, nicely done.
Wayne
Wanted
Apr 12, 2009 02:01 AM
tekgnosis
14
Sep 7, 2006 05:21 AM
nachomc
Nov 4, 2004 09:26 AM
cannibal869
Aug 23, 2004 09:11 PM
downshift
Aug 13, 2003 10:58 PM
