Check Engine Light
Old Sep 4, 2003 | 05:16 AM
lakepop's Avatar
Lightbulb
Well keep in mind that the OBDII system is very sensitive to emmissions. So if you forget to tighten down your gas cap OR overfill the tank by trying to round off the fill ups to some number.........you will probably get a "non blinking" CEL. Those are both YOUR fault.
Sorry you had the problem.....Subaru is no more sensitive to those issues than other cars......if it happens again ...try restting the ECU via the tried and tested battery disconnect method.
Hope this helps.....
Racerkid
May 29, 2012 06:16 PM
saab92x
Mar 16, 2009 03:16 AM
06scooby
Oct 15, 2006 10:11 AM
rash
May 17, 2003 12:32 PM
