Using 5W oil
So it seems most typical oils in stores are now 5W-30 or 40 or whatever. Would using a lighter weight oil be a good idea since it can still protect up to the same temperatures as the 10W-xx? I usually run Castrol Syntec 10-30 (40 when available) and I have the old school motor with hydraulic lash adjusters and synthetic seems to be the best with them. Thanks
Car Info: 98 Impreza RS
I think that would overall be a bad idea. Especially with older engines, it is better to run an oil with a higher viscosity than lower. I think it basically helps the worn parts of the motor to stay lubricated. So, i believe 20W would be better if you wanted to change it up, but 10W should be just fine. Just what I've heard.
Luke
Luke
SwtAzn_WRX_gurl
105
May 11, 2005 12:42 PM
Imprezer
Aug 8, 2004 12:44 AM
jacsmi
Jul 20, 2004 09:05 AM
international B
Mar 16, 2003 11:59 AM
