Spark Plug wires- any thoughts?
Old Mar 31, 2004 | 06:48 AM
Scooby_WL's Avatar
Car Info: 01 2.5 RS Coupe Silverthorne Met., leather interior, numerous mods
I've had Sparkco 9mm Blue wires for about 3 years now.
I've been very happy with the look and the performance "gains". However, recently a severe misfire in Cylinder #2 was traced to a bad plug wire. One of the Sparkcos burned a hole thru the boot.
I contacted Sparkco for a replacement, as they are supposed to be under lifetime warranty. However, I've heard horror stories about dealing with Sparkco.
What about Magnecores? Anyone have experience with their 8.5 or 10mm wires? Where do I purchase them?
Thanks!
Brent
tdibrent@hotmail.com
2001 Impreza 2.5 RS Coupe
Old Mar 31, 2004 | 02:16 PM
Jgrahn555's Avatar
Sarcastic Jackass
Car Info: i drive a beater
Go to google
search for the words Magnecore and Subaru
click away at the endless amount of information.
I definitely trust magnecore over some knockoff. With a name like "sparkco" isn't it obvious they're trying to ride on the tail of Sparco? Wouldn't that be akin to getting a motech system exhaust?
Old Mar 31, 2004 | 07:59 PM
Peaty's Avatar
I've used Magnecor on my RS they are good but OEM are also very good an don't cost as much. Wires will not give any performance gain. They will only be a detremant if they are bad is all.
Old Mar 31, 2004 | 08:40 PM
Wingless Wonder's Avatar
Origami posted by Scooby_WL
That shouldn't happen to a set of spark plug cables with good quality silicone boots. I don't think the exhaust manifold comes close enough to the boots to burn through like on pushrod V-8 engines.
Was the cable intact or did arcing burn through the boot? If the the cable had a break in it, it will try to arc to the nearest ground whenever that cylinder fires.
Old Apr 2, 2004 | 05:04 AM
Scooby_WL's Avatar
The cable portion is fine; the boot has a small hole about 2" up from the spark plug end; it started to arc through from the inside out, and was sending a spark to the inside of the head (spark plug bore).
I sent an email to Peter Luk at Sparkco at his request (He would not take any information over the phone); but have no response whatsoever yet. The wires do have a lifetime warranty, according to one of the distributors.
After reading the Mazda forums about their nightmares dealing with Sparkco, I'm not getting a "warm fuzzy feeling".
Better Business Bureau, here I come........
Old Apr 2, 2004 | 05:37 AM
Peaty's Avatar
Originally posted by mr. m
ive read that magnecors have a problem of popping off the spark plug.
I never had mine pop off but when you hook them on the plug you don't get that nice positive "Click" you get with the OEM plugs. I can see where they might comeoff. As I said it never happened to me but I too have read of people having this problem. I still think OEM are the way to go.
Old Apr 2, 2004 | 12:33 PM
Defiantguy's Avatar
Car Info: 2004 Subaru WRX
ya I 2nd the oem plug wires.
Old Apr 17, 2004 | 02:23 PM
gianttcr's Avatar
Car Info: '00 red impreza RS sedan w/ Borla hdr., Tanabe S. Medallion, P-slots,MSD wires, AEM, AGXs, Eibachs.
I found that you can modify a set of MSD wires meant for honda (prelude, I think). make sure on the length and you'll have to trim the rubber gasket on the extension as well cut the other ends and install MSD straight ends. Other than that no problems. Oh yeah, re-gap the plugs bigger too (.055-.060?)
Vizzionz
Apr 7, 2007 07:57 PM
DetailAddict
Oct 21, 2005 03:11 PM
Liigod
Jun 3, 2005 01:05 PM
Benjamin Tang
Dec 8, 2003 07:11 PM
burningphoenix
Apr 2, 2003 02:25 PM
