...top end work?
The common consensious is that the Perfect power is a great tool for tuning. At least right now. Supposedly Bill from i-Speed has finished his remap for the ECU but is in testing and marketing. So 2 months from now, supposedly, we'll have a reflash.
cheers
garrett
cheers
garrett
Originally Posted by cudaeh
port matching only takes about half a day and I noticed some improvement and is a great way to cut down on those long spool ups when you install an aftermarket turbo. You will need a die grinder and a couple of agressive bits..
has any one found a good piggy back that wont get learned around yet? every one i have read reviews on said "worked great for the first week then back to normal". would you guys recomend the rallitek one then take it down to a dino shop and get it tuned?... I didnt want to jack the tread but there are many threads like this with no resolution other than intake mods and safc's dont work.
nice hijacking!!! :-) ...i've been wondering about the same stuff. i want to know if my auto trans will be affected by an ECU. also what one is the most userfriendly/tunable for '02+ RS's. does anyone know these things!?!?!?! HELP!!!!
What I am running
I have a stock 98 and a modified 01 - Best guess from seat of the pants is I am close to 200.
STd 30,000 Mile block - Ported heads - Ferra Valves, Cobb Stage 1 cam, Borla Header. 11 lb flywheel, Under drive pulley, Ground Kit, Iridium plugs, K&N Filter in Opened up stock manifold feed by Stock scoop. Local build 2.5 inch exhaust to an eBay muffler - It’s loud but I can drive in police mode fine
My next purchase is the Perfect power piece and I also plan to do the iSPeed Re Flash once they have done a few more. Plan to raise rpm to 7500
I have sealed up the radiator for better air flow and put additives in the coolant to run as cool as possible - Hot here so that seems to cause worst damage
Drive mine daily and shift when the rev limiter goes - Beep Beep
On the right stretch of road it will all but redline in 5th and I have 22b wing and Greddy air dam
I want NOS or Turbo at times but sound so sweet from 5k up
Its a nice daily driver, I have to reset ECU about once every 6 weeks , but its getting better, The reflash should cure most of that, mostly from Flywheel I would buy 14lb if I did again just for that reason - 11lb rev's real fast
okaaaayyy.... was that advice or a classified add? ...if there is anyone with some constructive knowledge on ECU's or head work feel free to help. i'm pretty sure there's an entire forum dedicated to braggin about your "whip"... yo!
Braggin ?
We guess It was taken wrong
The objective of my post was to give you an idea of what I have been running and what I thought I was pulling horsepowerwise
I have a direct seat of the pants comparision -- My 98 is stock and 165 hp
My best guess is about 200 on my 01 based on the info I gave.
the most recent Subie sport has a similar article on comparable set ups
Sorry I tried to add a little humor - geez
jimtweet
Jul 19, 2005 05:57 AM
Jonnyboy593
Jul 8, 2004 10:41 PM
