Subaru is acting a fool! Help!
Old May 10, 2011 | 05:42 PM
burnyou2's Avatar
Car Info: 2002 BRP 2.5RS
So... I can't tell what it's doing. Here are the symptoms
When I get on the gas during acceleration, like on ramps or even just needing to speed up from 2nd to 3rd sometimes I feel a loss in power. It's sporadic, like when my foots on the gas it feels like it bogs/powers back/bog/powers back on and off, on and off. I have a bad knock sensor that I need to replace and thats all that I know that needs a fix.
From a dead stop it will bogg and then gain all it's power back all at once (if that makes sense) but that only happens once in a while, and it's not because of my ability to drive a standard transmission I assure you.
Car is a 2002 RS, 80K on it
Any help would be great.
-Robert
Old May 10, 2011 | 06:00 PM
DarkJuic3b0x's Avatar
Car Info: EQ Tuned * Corn Juiced '05 WRX
Any list of mods?
Old May 10, 2011 | 06:50 PM
Gancherov's Avatar
Car Info: 02 WRX Wagon
Sounds like it might be a fuel delivery issue. Mod list would be nice.
Does your car idle steady or is it a little rough? rough idle might point toward fuel issue as well.
Old May 10, 2011 | 08:47 PM
burnyou2's Avatar
Full header back exhaust. Borla header, Random technologies HFC, stromung catback. I have a very minor exhaust leak on the Header/HFC connection and really only is there during warm up until the gasket swells n seals. It used to have short ram intake but it's back to a stock intake.
Come to think of it, it does have a rough idle on occasion. Could the filter be clogged? I got fuel at a pretty sketch place coming back from vegas in the middle of East Jesus Nowhere, Nevada. Or is more of a bad injectors kind of thing?
Old May 10, 2011 | 09:06 PM
StealthMODE's Avatar
Car Info: @eatwithnaveed
If it sounds like it's choking, and you gas it and it just feels like it Boggs and dies, it could be as simple as bad spark plugs or bad coil packs. That's what happened to my old g35. It'd idle kind of roughly, it started randomly, and it wasn't too bad at first but it got worse by the day. Check the packs by interchanging them and sparks are cheap so get another set.
Old May 10, 2011 | 09:14 PM
burnyou2's Avatar
It's never died on me but it does bog sometimes when I'm trying to accelerate. It's very random and doesn't always happen
Old May 10, 2011 | 09:42 PM
wrex006's Avatar
Car Info: 2008 AW FSXT
Do you have HID?
Make sure the grounds are to metal in the engine compartment.
My 02 wrx did this and I re-grounded the wiring harness and used a dremmel to scratch off the paint for the grounds.
Old May 10, 2011 | 09:51 PM
Mt.STi's Avatar
Car Info: '05 psm STi
check your hoses for cracks
Old May 10, 2011 | 09:55 PM
burnyou2's Avatar
Thats what she said?
no but really, I do not have HIDs. Has new hose lines for air... Which are you talking about?
Old Sep 20, 2011 | 12:54 PM
railz's Avatar
Car Info: STI
im also having the same issues on my 02 2.5rs except ive done everything i could think
changed plugs,wires, switched out coil pack with a known good one, replaced knock sensor, MAP sensor,fuel pump, fuel filter, Crank sensor, Camshaft sensor
NOTHING worked
and just like you, mine will drive perfectly fine at times and then go to hell and go back to normal..
Old Sep 20, 2011 | 01:01 PM
burnyou2's Avatar
Yeah I'm still chasing my issue:-/
Old Sep 20, 2011 | 01:11 PM
Shayhan27's Avatar
Car Info: LUMPY CGM 05 WRX
How are you tuned?
When you went back from the short ram did you unplug the negative on the battery to reset the computer?
Also the knock sensor being bad may be causing the computer to pull timing....
My wrx did this when I had a k&n typhoon on a cobb stage two....When I put the stock intake back on and reset the computer it fixed the problem.
I am really inclined to say the knock sensor is pulling timing though....
Old Sep 20, 2011 | 01:14 PM
jdblock's Avatar
Car Info: 2004 STI
Try cleaning the MAF sensor. Could be giving a bad reading to the ECU. Is the air filter dirty?
in3g_wrx
Sep 1, 2008 12:35 AM
Jizzo_02SubiWRX
May 31, 2005 06:11 PM
foeshaz
Dec 8, 2004 09:21 PM
midnightwrx
Dec 7, 2004 03:54 PM
pdqwrx
Mar 31, 2004 01:17 PM
