STINKY engine, burning something!
Old Dec 14, 2003 | 09:07 PM
meilers's Avatar
I have a 2.5L Legacy Wagon, and after I park it, that thing STINKS -- a very nasty smell coming from right under the hood, like burned oil. I checked the oil level, and it is fine; all of my other fluids are also topped off. The engine only has 36k miles on it, so I don't think I need piston rings or a cylinder head gasket... What could be making that smell?
Old Dec 15, 2003 | 02:38 AM
whitelegacy98's Avatar
is there any oil smoke from your exhaust? and tho I doubt it, I gotta ask is it possibly a burning clutch?
Old Dec 15, 2003 | 06:17 AM
meilers's Avatar
It is an automatic so I am absolved from mistreating my clutch. No, I know what clutch smells like, this is different.
Old Dec 15, 2003 | 08:48 PM
sixjoe45's Avatar
Car Info: 1999 Legacy L
Have a subaru mechanic check the cam cover gasket, my 99 had one go bad and it smelled horrible. I used some gasket stop leak from pep boys and it made it bearable for a while.
Old Dec 15, 2003 | 08:56 PM
meilers's Avatar
You know, I will bet you $$ this is the exact problem. I spotted some SMOKE(!) coming from the engine last night; I drove it until I smelled the stink and then pulled over and popped the hood immediately. The smoke was coming from the back rear of the engine, way down underneath. For a second I thought I had a fire in my oil pan!
Old Dec 16, 2003 | 04:24 PM
Lavery's Avatar
Car Info: 98 Impreza RS
I had the same thing. Here's a link to a previous thread when i had my problem. Oil leak onto header
luke
Old Dec 16, 2003 | 05:12 PM
this was some good advice from the other thread:
Originally posted by X1_SRT
if you're having it all taken apart, have him do everything. when i worked in the shop we would almost never replace one seal behind the timing belt. if the timing belt comes off, we told the customer that they should all be replaced. and this was not a sales ploy.
if just the crank seal is leaking now, the oil pump and o-ring will leak shortly. replace oil pump seals(o ring, and grey rtv cement between oil pump and block), front crank seal, and cam seals as well as timing belt. we saw far too many "well just do that one" sort of things. a month later they come back, yelling and screaming b/c they are leaking again, and we didn't fix the problem. it just saves time and energy, and money to do it all at once. and then you're good to go for another 60-100k.
-PJ
Old Dec 16, 2003 | 06:38 PM
meilers's Avatar
With only 36k on this engine (which means at least 36k more on the timing belt, I hope!) I doubt this is severe enough to need that much work -- perhaps Arizona heat has cooked my engine??
I'll let you know what the problem is once I get it into the shop.
JelloChex
Dec 7, 2009 03:11 PM
G-Force
Jul 1, 2006 02:59 PM
specb
May 3, 2006 07:57 PM
doogie2756
Mar 1, 2005 06:10 AM
Gunslinger
Sep 29, 2003 11:07 AM
