Spark Gap
Old Sep 12, 2004 | 03:39 PM
NaT NaTe 1 8 3's Avatar
Car Info: 2007 Subaru Legacy SE
Spark Gap
I have an OBS (EJ25) and can't find what the spark gap should be. Does anyone know?
Old Sep 12, 2004 | 08:57 PM
Sparky280's Avatar
the gap i belive is 0.39 - 0.43 the NGK Coppers I use come gapped at 0.44 which is fine.
Old Sep 13, 2004 | 12:05 AM
Kostamojen's Avatar
NASIOC Slut
You dont really need the platinum/etc. plugs anyhow with the N/A motors.
Old Sep 13, 2004 | 02:05 PM
I already went with platinum, and the factory set gap was between .044 and .045. Thanks for the input.
Old Sep 14, 2004 | 04:51 PM
bheinz57's Avatar
Car Info: '02 OBS '03 Baja
Do not attempt to gap your plugs if your using platnum, or another precious metal, there is a high chance that you can rub the very thin layer of that metal off, making them worthless
That was a qoute from above^^ And that is also why platinum and other alleged precious metal plugs aren't worth crap. Get regular NGK's or even copper and everything will run fine. Screw Iridium and all that jazz. My opinion.....Brian
ROSSCAD
May 7, 2005 05:11 PM
simpwrx02
Oct 23, 2003 10:30 PM
pete57
Oct 1, 2003 12:58 PM
mario
Jun 11, 2003 03:27 PM
aaronthehic
Feb 14, 2003 11:00 AM
