P0420 code and I'm pissed
Old Aug 23, 2008 | 06:11 PM
smokey25's Avatar
Car Info: silverthorne 2000 2.5rs
**** you stupid cat **** you in the ****ing *** **** you you ****ing monkey ****ing **** **** you.
Had a P0420 code on my 2000 RS for awhile after a blow headgasket. Replaced the cat today, no CEL after running for awhile at the shop. Of course, 4 blocks down the street, CEL comes back on. Might be a different code, and maybe one day pigs will fly across the sky as free as birds.
Old Aug 23, 2008 | 06:44 PM
RaginBull's Avatar
Car Info: E46 M. E36 M. E30. SW20. 92 VWCab.08 Civic HYBRID
When I threw a p0420, i had my cat replaced and that fixed it. Its probably something else
Old Aug 23, 2008 | 06:56 PM
Roo's Avatar
Roo
Forester Specialist
Car Info: '98/'04 Foresters (S & XT)
Let me guess.
No on the new oxygen sensors? I'd guess they're fouled or something, and are giving you false readings, since you had the head gasket issue. If you have replaced both oxygen sensors, then I'd start the swearing, but hold off until then if I were you.
Old Aug 23, 2008 | 07:47 PM
smokey25's Avatar
2 oxygen sensors costs more than the cat does. Do you think cleaning them might help? I am thinking of just installing one of those rear sensor "extenders" that keeps the sensor farther from the exhaust. Seems to solve alot of problems with other people who have had P0420 and replaced cat and sensors to no avail.
Old Aug 23, 2008 | 08:25 PM
I<3subie's Avatar
banned
Car Info: heel'n toe da hoe...
Just tune it off.
Old Aug 23, 2008 | 09:38 PM
DetailAddict's Avatar
Former Vendor
Car Info: Evo X
just replace the front... the rear is for reading but doesn't actually do anything... always change your front o2 if you blew a head gasket... I am sure Roo or Unit 91 can help you with the part number and price. Good luck!
Old Aug 23, 2008 | 10:45 PM
Unit 91's Avatar
i-Club Sympathizer
All the rear does it make sure the cat is working. The front is usually why you'll throw a code. Are you SURE the cat was bad and not just the sensor in the first place?
Anyhow, I can get you more info on Monday if you want.
Old Aug 24, 2008 | 10:16 AM
smokey25's Avatar
Right on man thanks for the help. Well, the code said cat. And after some research, and the fact that my car smelled, I just kinda figured it was the cat. I am actually right now in the process of importing this car into Canada so that is why this is all getting done.
Right now it would be nice to get rid of the CEL without spending another 200 bucks for the front sensor. I can take it out and look at it, is there something I should be looking for to tell that it is bad or fouled up? Can I clean it? And is it a bad idea to go to a pick-a-part and get a used cheaper sensor that way?
Old Aug 24, 2008 | 02:15 PM
STi-owns-evo's Avatar
Car Info: '02 PSM WRX
$200 for an O2 sensor? Where do you shop for your parts?
Sparkplugs.com has a Bosch OE identical for $60. http://sparkplugs.com/more_info.asp?...9402&pid=31667
Old Aug 24, 2008 | 02:45 PM
smokey25's Avatar
Just what I was quoted recently but maybe the parts are more expensive here in Canada, who knows. Is that one you pointed me to the right one for a 2000 RS?
Old Aug 24, 2008 | 03:39 PM
I<3subie's Avatar
banned
Wow... Did california / North Bay area move more north and not say anything on the news?
Its $200 Canadian which equals out to be $60 U.S. Thats why.. Watch out for the duty tax..
Old Aug 24, 2008 | 06:31 PM
kYLEMtnCRUZr's Avatar
first impression: cat **** on your car?
Old Aug 24, 2008 | 10:47 PM
I read "in the process of importing" so I thought you were still in the states. And yes, the link is for a 2000 RS, it should have the car information right under the "More Info" bolded title. I have no idea how hard it is to install the front O2 sensor on a suby, but I had to recently change one on my stepdad's Honda, and after I bought a O2 sensor socket, it was really easy.
I have no clue what you're trying to say here
Old Aug 25, 2008 | 02:59 PM
smokey25's Avatar
Good news, I guess. Turns out the code now is a knock sensor. So the cat did get rid of the P0420
Old Sep 2, 2008 | 08:36 PM
yanimaya's Avatar
Car Info: 02 WRX wagen
Knock sensor is not a cheap too, buddy, on worldpac, the price is $97.95.
but hey, here: http://www.rockauto.com
you can find your knock sensor here, for $44.89, it is oem part, hope this link can help you.
