p0420 cel
Old Jun 6, 2006 | 07:21 PM
stevemasteller's Avatar
p0420 cel
i have a '01 rs and put a borla header on everything else is stock. i keep getting the p0420 cel code. is the mechanical cel fix the best. (this may be a dumb question but) if so do i put it on the front o2 or rear. i am also getting some popping from the exhaust is this normal?
Old Jun 6, 2006 | 09:30 PM
Peaty's Avatar
http://www.scoobymods.com/forums/showthread.php?t=5468
Old Jun 22, 2006 | 09:56 AM
Siper2's Avatar
Car Info: 2005 Legacy GT Ltd, 2001 Outback LL Bean
Well, Pete's method will work, or you can buy the PDM O2 bung extension:
http://www.tarmac-usa.com/CandyPress...p?idproduct=74
www.boxer4racing.com sells them too, but they were out of stock when I ordered mine.
That screws right in, don't need to drill anything.
However.... mine doesn't eliminate the P0420 light for more than a couple days. Helps, but only temporarily. The MIL Eliminator (electronic fix) only works for cat-delete track pipes. If you use that and have a high-flow cat, you'll get a P0136 instead (voltage error). So don't.
The only fix is a propsed P0420 elimination that www.i-speed.us is reportedly working in to their next round of SRS-10 and SRS-20 ECU reflashes, due out in late summer or so.
=S2=
smokey25
Nov 7, 2011 09:22 AM
kenji815
May 26, 2006 01:31 PM
DarkAngel
Jun 14, 2004 10:59 PM
nodoz781
Dec 1, 2003 06:35 AM
