oil puking out off my timing belt cover
Car Info: 95 awd impreza
my 95 impreza 2.2 has sprung a leek. I have oil driping out from my timing belt cover runing down the oil pan then blowing back onto the y pipe.
Its not alot but it smells! How many seals are back there? This looks like its going to be a pain in the *** to fix, think I'm going to have the dealer do it. To bad it already has a new timing belt with 20,000 miles on it.
Admin v2.0
Car Info: 02 Black Legacy GT
If the oil comes out from your timing belt cover it could be a number of things.
Most likely it is either the oil pump seal/gasget or the cam seal.
You can take the covers off and see where the oil is coming from.
We had our crank seal go at around 70K at the time I had them change the timing belt and water pump. I hope your new belt is OK, it may have gotten oil soaked.
Here is some info on the oil pump seal:
http://www.endwrench.com/pdf/engine/...alsInfoW99.pdf
all fixed : new crank seal, water pump, thermostat, readiator hoses, timing belt, timing belt tensioner, and a new rubber boot for my rack and pinion to replace the one i tore on a off road excursion.
TOTAL INVOICE $ 853.30
Heedz
03-15-2015 04:32 PM
CCC
Engine and Drivetrain
02-02-2012 10:09 AM
strider327
03-11-2009 12:38 PM
