need advice: spark plugs and suspension
Old Dec 7, 2005 | 01:34 AM
shum_87's Avatar
Car Info: 2001 Subaru Impreza 2.5RS
Smile need advice: spark plugs and suspension
I'm currently driving a '01 2.5RS. the only change I've made are the lights; sylvania silverstars.
I just need some simple advice: which type of spark plugs i should look into and what should I do about the suspension (in means of shocks, sway/strut bars, etc.)
thing is, I'm currently working off of a modest income, so I want to make the right choices before spending the money.
so any advice would be much appreciated!
Old Dec 7, 2005 | 07:55 AM
DreddRS25's Avatar
Car Info: BRP Impreza RS MY01
NGK V-Power Spark Plugs BKR6E-11 gapped to 0.044 (something like that).
Best $7 spent for plugs.
Edit: 02/03 WRX rear sway bar is the best first suspension mod.
Old Dec 7, 2005 | 12:32 PM
Checkpoint's Avatar
Car Info: 00 RS
NGK
If you have the money buy some DMS coilover 50mm. Best damn suspension ever.
Old Dec 8, 2005 | 12:38 AM
Dylan's Avatar
Car Info: 01 GME(6) / 04 GDF(7)
For the susp., PM scoobyrs25 over at rs25.com site, he's got a good deal on coilovers. GL
Old Dec 13, 2005 | 08:14 AM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
what's a "modest income?"
I switched to NGK Iridium IX from running coppers for 2 years (coppers you need to change 10k-15k), and these things are great. Iridums are good for about 30k.
I'm running DMS40's with 350lb front and 300lb back, DMS solid plates all around, and that costed me $2000... that was hooked up through DMS NA since I know Mark there. My set was a rebuilt set he had laying around. Retail, it's a $3200 with all the stuff I have on there.
DMS 50mm is nearly $4200 starting out!
If you need a budget coilover, try the Megans or the Helix ( www.Gruppe-S.com)
Prodrive springs and AGXs with at least a 20mm rear sway bar is probably what you are really looking for right now, and should run you about $750.
-Gagan
Old Dec 15, 2005 | 01:11 PM
AWDimprezaL's Avatar
nkg absolutly NO bosch...subies hate them
Old Dec 17, 2005 | 07:54 AM
joltdudeuc's Avatar
Old School
Agreed. Denso or NGK are pretty much all the the subarus like. Bosch does not work well in our cars.
-Gagan
Old Dec 19, 2005 | 11:58 AM
shum_87's Avatar
-Gagan
.. as in I'm not making a lot of money, therefore I don't have a lot to spend ..
Old Dec 19, 2005 | 12:07 PM
shum_87's Avatar
alright .. so I should suppose ngk is the way to go.
now are there fundemental differences between the v-power and the iridium ix plugs?
Old Dec 22, 2005 | 11:15 AM
shum_87's Avatar
quick question: I've found 'strut mounts' are available for purchase; would I need to get a set?
thanks for the advice.
Old Dec 22, 2005 | 11:57 AM
joltdudeuc's Avatar
Old School
what's your budget for all this?
strut mounts alone? no, no need. they would be nice to have upgraded ones with an ungraded suspension.
-Gagan
Old Dec 30, 2005 | 01:57 AM
shum_87's Avatar
I'm looking into spending around $2000 right now.
I figured that my first mod to the car should be suspension and control, and also a small 'upgrade' with spark plugs.
Old Dec 30, 2005 | 11:49 PM
joltdudeuc's Avatar
Old School
If the car is pretty much a street driven car, and not raced much in any form of motorsports, those Megan Coilovers are great for street driving.
You can use the rest of your 1100 on other tidebits. I'd suggest tires and wheels as well... this should put you at $2000
-Gagan
Bagin,DVS
Mar 25, 2008 10:22 AM
DetailAddict
Oct 21, 2005 03:11 PM
shaniazy
Feb 22, 2003 10:34 AM
shaniazy
Feb 22, 2003 05:37 AM
shaniazy
Feb 22, 2003 05:28 AM
