Most HP for the $?
Old Feb 3, 2004 | 01:24 PM
  #35
Sparrow's Avatar
Car Info: 98 Legacy
Can you explain how you could get more lift without adding material to the lobe?
I am no engine builder, but I would have to guess that since all valves have some adjustment (shims/spacers) of sorts that you may need to just pick up the slack on the low side of the cam and viola! more lift/lift time on the high side?
Perhaps I am confused??? Anyone?
Old Feb 25, 2004 | 07:39 PM
  #39
scoobylvr's Avatar
Car Info: 1998 Impreza L EJ22
cool
Old Feb 25, 2004 | 07:40 PM
  #40
scoobylvr's Avatar
really cool
Old Feb 25, 2004 | 07:41 PM
  #41
scoobylvr's Avatar
now-senior member
(sorry for postwhoring)
Old Mar 3, 2004 | 09:20 AM
  #43
WRX_REED's Avatar
Car Info: MY2000 RS cpe Sedona Red
Another option I am surprised that no one has mentioned, is that if serious about bang for buck, NOS has 50-100 HP shot systems that by far blow away anthing else you can come up with short of forced induction. The new NOS systems are not the old open the valve and wait for the bottle to empty before a curve comes up or crank snapping systems. But rather they have new systems that are controlled shots that provide enough laughing gas to boost your *REAL* HP to the stated system levels for a few seconds which are great for drag runs and quick boosts of power (as opposed to regular bolt-ons that 1. are not linearily compounded when combined with other add-ons (stated 5 hp gain for intake, and stated 2 hp for pulley does not, and generally will not equate to 7 hp total, most people don't realize that everything affects everything else in relation); 2. total cost to just reach a probable level of 20-35 hp can be incredibly expensive as opposed to using the NOS system. Same reason why it's more cost effective to go forced induction in the long run; and 3. Can make the car uncomfortable for anything but the track.). Now the cons to this are still the stigma of reliability, again these systems are made to be used with the stock setup of most N/A cars, however as with anything performance oriented, there is lost of room for user abuse. If you have a 50HP 8 shot system, you are not suppose to keep juicing the engine with multiple continous shots on a single run with the NOx. Also the cost, though the best bang for the buck, it still requires a hefty buck. So in short, if you really want to get the biggest, best bang for the buck you may want to look at the NOS systems before caming out, or exhaust modding the car and affecting it's street-ablity, and possible Emission issues. If all you are concerned about is power for the cheap. If sound and looks are more important than pure power then, the lesser mods are better suited for limited gains. Just my 2 cents.
- WRX_REED
Old Mar 10, 2004 | 03:13 PM
  #44
Mat - 98 R/T's Avatar
Car Info: '98 Neon R/T
I'm not too keen on reground cams, personally. I was even nervous about my cast Crower cams. AFAIK, only Crane uses billet to make their cams. They don't advertise on their site, but they may make you something custom for the same cost (or less) as Cobb.
VividRacing
Vendor Group Buys/Specials
Dec 28, 2002 12:35 PM
Snarlynx
Dec 24, 2002 12:18 PM
capt'n'caveman
Nov 30, 2002 03:14 PM
GotsMeATurboRS
Nov 22, 2002 09:49 AM
