I have a 2000 Impreza RS 2.5 HELP ME OUT
Old 08-27-2003, 01:38 AM
Cobb intakes are the best, but you want to save some cash, so go with a PDM intake from www.pdm-racing.com for $55 and a K&N. Avoid open-element filters like you used to see on every Honda you ran across, they are bad for high-displacement torquey engines like the EJ25.
I see you already bought a muffler, so I'll skip exhaust advice other than to suggest you get your favorite local muffler shop to fab you a new midpipe, 2.25". 2.5" will work okay but loses a little bit on the low end compared to 2.25". Shouldn't run more than $150 installed. MRT headers make a lot of power and are only $300 + shipping. Other than that, there aren't a lot of cheap options for making power. Some will recommend pulleys, but I don't.
Kevin M is offline
Old 08-30-2003, 09:11 AM
johndoe's Avatar
Car Info: wrx tooooo much invested
If you want alot of power for cheap i have my stock Manifold up pipe and down pipe with the stock turbo from my 2002 WRX. you could run about 8lbs. of boost and get your car at about 250 hp. If your interested e mail me at M5speeed@aol.com oh and i'm only looking for $750 for everything. I just want to get rid of it.
thanks Mike...
johndoe is offline
Old 08-30-2003, 09:36 PM
You can't run WRX headers/uppipe on an RS without a turbo crossmember. If you want to run WRX parts for an RS-T, you need either the WRX crossmember or custom up and down pipes.
Kevin M is offline
djstatistics
04-08-2014 11:31 PM
maxia001
06-01-2013 04:26 AM
sleepy
02-07-2011 09:56 PM
_The_Doctor_
10-24-2004 07:42 PM
newtosubaru
12-30-2003 09:53 PM
Quick Reply: I have a 2000 Impreza RS 2.5 HELP ME OUT
