Higher Octane Gas does....
Old Mar 12, 2003 | 09:38 PM
joltdudeuc's Avatar
Old School
Car Info: '99 RBP GM6
what to an RS?
I have a 1999 2.5 RS
Perrin Filter
Stromung Cat back
Ground wire Mod
I've ran 87 octane forever, and started using 89 for safety reasons, as i run the car hard, and wouldn't want it to ping, so a little extra protection there. First tank, car ran sluggish. 2nd tank, car ran ok. this is my third tank, and the car's revs have smoothed out a little, and the car pulls cleaner now.But the jumpy torque is gone.
Am I just imagining this? I was under the impression that the ECU wouldn't advance timing for higher octane gas. Is something else going on here?
The few times i've put in 91 for kicks, the car had become sluggish.
-Gagan
Old Mar 12, 2003 | 10:55 PM
brento's Avatar
Car Info: 02 RS
for me i tired plus for a few fillups and then i tried premium for a few fill ups and all i noticed for milage and performance was nothing. just alittle less money in my pockets.
but that is only my opinion. i have an pdm intake, K&N filter, and a lightened pulley.
Old Mar 12, 2003 | 10:56 PM
joltdudeuc's Avatar
Old School
i don't think i got any power...
it just feels so much, better...
i dunno
-Gagan
Old Mar 13, 2003 | 02:50 AM
Scubaru's Avatar
Car Info: MY02 GD WAGON, MY87 AW11
I too noticed sluggishness when I changed grades or fuel brands, it'll take about 2~3 tanks for your ECU to readjust to the new fuel-hence sluggy....
Old Mar 13, 2003 | 08:37 AM
joltdudeuc's Avatar
Old School
cool. I'm at that point. what did the ECU do?
-Gagan
Old Mar 13, 2003 | 09:48 PM
Scubaru's Avatar
Maybe it's something to do with how fast 87 burns compared to 89 or even 91? Im not sure......
Old Mar 14, 2003 | 08:30 PM
I switched to 91 the day I performed my Snorkelectomy, which was in December. I noticed a couple things. First, EJ25s have MASSIVE intake noise when you uncork them! Second, the car had a deeper exhaust note at idle and part throttle on the 91. Third, I am getting 1.5-2 mpg more by using 91. That means it's paying for itself, plus I get better knock protection.
I am hypothosizing that by switching grades and opening up the intake, I forced the car to run leaner without retarding timing, which seems to have had a slight effect on power and throttle response. I still shudder when I look up after adding 13 gallons, but I remind myself that I got 30-40 miles farther by paying an extra $3, plus the side benefits. I know it might be purely the placebo effect, but I feel like the switch is worth it.
Old Mar 18, 2003 | 05:07 PM
Myxalplyx's Avatar
Gains
There was a guy on the 'other' subaru board that wanted to know the same thing that some of you guys want to know. He tested 89 and 93 octane gas to see if any changes in the way the engine operates took place. He looked for changes on his PocketLogger.
What he had found out was that timing was more advanced with the higher octane gas than with the lower octane gas. As far as I can remember, no hp/torque gains or gas mileage was tested.
At any rate, he did find out that the Subaru ECU does make adjustments with a different grade of gas. If you have a factory service manual, you'll notice that on most Subarus (as far back as 1989) the ECU will adjust timing constantly to get the most advanced timing it can up to a point. I just don't know what the timing limit is.
I personally tested different octane gas at the dragstrip with an ECU reset. What I found out is that with both of my cars (1989 2.7ltr Subaru XT6 and 1997 2.2ltr Impreza), they both performed slightly worse with higher octane gas. Torque on the low end 'seemed' to be improved and the car got noticably more responsive on the low end.....especially right off idle. Even with higher 100+ octane gas on an N/A engine the car seemed even MORE responsive but 1/4 mile times got even slower still. I was familiar with the reasoning behind this but I had to find out for myself. *What's important to know about this is that even though the car was slower, the 1/4 mile time could've still come out the same due to the responsiveness increase of your off-idle. You would have to take advantage of this though with good tires and good traction (60ft times)*. The differences of the 1/4 mile times was within 2/10ths of a second but it was consistent.
You are encouraged to test this out to find out how different octanes perform on your own car since everyone's car doesn't react to a change the same way. Take Care!
Old Mar 25, 2003 | 04:44 PM
Kay95's Avatar
87 octane might perform better but here in PA 87 octane at some gas stations is or at least seems to be cut with water or something that makes my 95 1.8L run bad. The only way to combat this is to buy 94 octane or 91 octane depending or where I buy at. But in other parts of the country this may not be a problem.
Old Mar 25, 2003 | 05:14 PM
94 octane... my god, what I could do with 94 here in California!
mooshoo
Mar 2, 2013 08:52 AM
0260B4U
Feb 6, 2004 06:12 PM
mmboost
Aug 18, 2003 01:45 PM
blackwagonrx
Mar 1, 2003 01:41 AM
