high compression.
Old Sep 14, 2005 | 05:33 PM
GrandpreRS's Avatar
high compression.
What do I need to do to raise my compression. 99 2.5 gc8 sohc. planning on cobb cams and need new rod 'cause of slapping on one cylinder. know of any cheap oem pistons and rods or high compression pistons? would probably shave block and thinner gasket. have 9.7:1 would like around 12:1.
give me some sites or manufacturers.
thanks.
GrandpreRS
Old Sep 22, 2005 | 02:58 PM
1SIKBRU's Avatar
Car Info: Audi Q5 aka "the old man wagon"
http://www.teaguesauto.com/motor.htm
if u scroll down to the bottom u will find some piston sets but they aren't cheap at all. they also have just about anything you could want for ur car.
Old Sep 22, 2005 | 05:18 PM
svek's Avatar
Car Info: '99 2.5rs - Rally Blue
your CR is 10:1 btw. a thinner headgasket will raise the CR. you can get some 11.2:1s from http://rallitek.com/products.asp?ID=...Y&HB=&ACC=&SP= there.
________
Wiki
i2()N!N
Feb 9, 2005 04:15 PM
Fade2Black
May 8, 2003 05:40 PM
fast legacy
14
May 7, 2003 12:23 AM
rayjle
Apr 5, 2003 12:17 AM
bedarddc
Jan 5, 2003 10:50 AM
