help... what engine should i use
Old Dec 7, 2003 | 11:25 PM
joubtt's Avatar
Car Info: 00 2.5RS
Check here www.i-speedusa.com , www.gruppe-s.com , http://forums.nasioc.com/forums/foru...php?forumid=87 ; use for basic-detailed information.
Old Dec 8, 2003 | 07:15 PM
my25rs's Avatar
Car Info: 00 impreza rs
As for me i would recommend just going for the ej20t, u don't have to spend lots of money compared to the ej25
Old Dec 9, 2003 | 02:51 PM
Frink's Avatar
Car Info: 2005 Legacy GT MT
I'd just sell your car and use that extra money to buy either an RS or WRX. Save yourself alot of work and headaches. Probably cost you about the same when its all said and done. (well for an RS at least)
Old Dec 11, 2003 | 09:31 PM
joubtt's Avatar
Car Info: 00 2.5RS
Anyhow if you've the $$ to play with, just buy a used WRX and go from there.
Old Dec 12, 2003 | 06:46 AM
ImprezaVA's Avatar
Car Info: 1998 Subaru Impreza L 2.2
Those links listed above will tell you a lot more than I can ever tell you. However, it's my reasoning that although you can turbocharge the 2.5 liter RS engine, it is open deck meaning that the EJ20T will be more reliable since it, I think, has a closed deck. Taking price into consideration, the 2.5L swap will be cheaper, but if you are thinking of going turbo, it would probably be cheaper just to go ahead and get the turbo EJ20 motor.
-Charles-
Old Dec 12, 2003 | 07:14 AM
Frink's Avatar
I agree, if you want to go turbo use the EJ20. The EJ25 has a higher compression ratio so you would have to run low boost if you wanted to keep it somewhat reliable. Not to mention thats another can of worms your opening when you decide to turbo an EJ25 along with an engine swap.
gillz
Aug 21, 2011 10:21 PM
Fade2Black
Dec 15, 2005 07:43 PM
Fade2Black
Dec 11, 2005 02:46 AM
Fade2Black
Sep 29, 2005 10:05 AM
chargespeed2.2l
Feb 9, 2003 09:55 AM
