help ! ticking
Old Mar 20, 2003 | 09:36 AM
subysteve's Avatar
Car Info: 2001 impreza rs
help ! ticking
i have a 01rs with 17k miles on it , and lately from 2-4k rpm it is ticking way more than usual , any ideas what it is , valves? , is it just me? , has any1 else had this problem , wierd cause car only has 17k
thanks for the help
steve
Old Mar 20, 2003 | 07:27 PM
live311's Avatar
Does it do it when cold or after the engine is warmed up? If it does it when cold, it could be the cam belt tensioner. Common problem with WRX's. Could happen to your car, too.
Oh, and DO NOT use Slick 50 for any reason. Teflon was not meant for use in engines. It can't handle the heat.
Old Mar 21, 2003 | 12:46 AM
subysteve's Avatar
it does it even when warmed up , i always warm it up at least 5 min no matter what weather condiiton outside , how do i check the tensioner , do you think it maybe be my oil i checked it is on correct level i am running a 5-30 syntec blend , the oil gage the thing that read " at oil temp" fashed on me once , i waited turned motor off , kicked her right up and nothing , i am clueless , i mean it isnt like a catastrophic noise but still annoying for a car with 17k on it
thanks for all info
Steve
Old Mar 24, 2003 | 10:41 PM
stan187's Avatar
Car Info: subaru impreza 2.5rs 1998
Yea mine ticks too but mine are the rods. Hope you dont have internal injuries like I do get it checked out before it causes more damage. Or you will be looking for a new engine like I am. Good luck!
Old Mar 27, 2003 | 02:48 PM
ilmaestro's Avatar
Car Info: 98RS - Pretty Blue
Originally posted by N/ABeast
My car sounds like a sewing machine when its cold..
ditto - 98RS
Old Mar 29, 2003 | 09:57 PM
I believe I too am getting louder clicking and ticking noises at idle and low RPM. Not positive though. I'm conveniently ignoring it though since I have abuot 25k left on the powertrain warranty and haven't noticed a loss of power or mileage.
Old Mar 30, 2003 | 06:40 PM
Carl,
what kind of flush would you recommend? The rational part of my brain comprehends how one type of lubricant can be temporarily substituted for another, but the part that makes me race is horrified by the idea of ATF in my engine. Engine flush seems much safer.
Old Apr 3, 2003 | 06:09 PM
joeathome's Avatar
Car Info: 2003 wrx
it seems possible to run trannny fluid in the engine as it takes a higher heat load than engine oil. found this out when the mechanic put engine oil int the tranny by mistake (newly installed tranny). A unit drove the patrol car out and got about 2 - 3 kms. before it literally blew a hole out the bottom and destroyed the new tranny.
EK
Dec 2, 2014 02:23 PM
EK
Dec 2, 2014 02:21 PM
dartheadz
Feb 17, 2004 05:40 PM
scobaru
Mar 2, 2003 06:26 PM
AFIwrx
Feb 26, 2003 11:18 PM
