help starting problems
Old Jul 23, 2008 | 10:40 AM
96Imprez's Avatar
Car Info: 1996 Impreza Brighton bone stock sadly
After driving my car and letting the engine warm up after i turn it off it won't start until the engine cools down, i thought it was my fuel system so i started small and while changing the fuel filter i checked to see if it was the fuel pump (disconnect the fuel line from the fuel filter and turn to the key to the on position to see if its pumping gas) well its not that, after hooking everything back up (thinking the filter was dirty/clogged) it still pulls the same stunts, if anybody has any ideas please throw them out here, could it be my injectors?? TIA
P.S. my battery is fine, i've seen threads similar to my problem but a battery change help them so that can't be the problem in my case again TIA
Old Jul 23, 2008 | 01:57 PM
96Imprez's Avatar
bumptizzle
Old Jul 23, 2008 | 02:05 PM
had similar problems on by bug but it was the fuel pump everytime in my case..
Old Jul 26, 2008 | 06:01 AM
chris8c8's Avatar
Car Info: none
try the ignition coil it tends to go bad with some subies
a1rush
Feb 8, 2007 06:43 PM
grex767
May 27, 2006 10:37 AM
Chubby Bunny
New England
Jan 30, 2003 04:17 PM
GLturbo
Jan 29, 2003 10:48 PM
cthulu5
Jan 6, 2003 12:13 AM
