help starting problems
Car Info: 1996 Impreza Brighton bone stock sadly
After driving my car and letting the engine warm up after i turn it off it won't start until the engine cools down, i thought it was my fuel system so i started small and while changing the fuel filter i checked to see if it was the fuel pump (disconnect the fuel line from the fuel filter and turn to the key to the on position to see if its pumping gas) well its not that, after hooking everything back up (thinking the filter was dirty/clogged) it still pulls the same stunts, if anybody has any ideas please throw them out here, could it be my injectors??
TIA
P.S. my battery is fine, i've seen threads similar to my problem but a battery change help them so that can't be the problem in my case again TIA
TIAP.S. my battery is fine, i've seen threads similar to my problem but a battery change help them so that can't be the problem in my case again TIA
a1rush
Feb 8, 2007 06:43 PM
grex767
May 27, 2006 10:37 AM
