funny idle
Old Dec 18, 2002 | 01:21 PM
DetailAddict's Avatar
Former Vendor
Car Info: Evo X
what year is your car? what octane do you use? bad injector(s)? Try junk yard for the o2 sensors... good luck!
Old Dec 22, 2002 | 10:13 PM
I am quite certain it's the O2 sensoirs. Bosch is quality stuff, but either you have the wrong type or they just haven't quite figured yours out yet. Get some OEMs in there and your problem should go away in a few days, provided you get the CEL cleared out.
Old Dec 23, 2002 | 07:17 PM
Originally posted by Silverscooby27
I'm having the exact same problem. I too have a 99. I too have a CEL, but haven't pulled the code yet. My hunch is that it might be the lightened flywheel. I have an Exedy. I'm wondering if it's maybe too light to keep the engine running? What do you think?
What other mods do you have? Anything that messes with VE, like intake, headers, exhaust etc. can be a culprit, but I don't see why a flywheel would cause problems. As usual with Subaru I would expect it to be O2 sensor or MAF sensor related.
Old Dec 23, 2002 | 08:03 PM
Originally posted by booger
i agree the flywheel is not causing the problems, but the problem is more pronounced because of it. Ill post more once my 02 sensors get replaced on thursday
Upon further pondering, I suppose that the increased rates of acceleration/deceleration of combustion could cause strange burns during throttle transition, and might make you spit out some unburnt fuel, which naturally causes O2 CELs.
Old Dec 23, 2002 | 08:21 PM
Do you have a PEMS? If so, you might want to retune it, becuase I guess the flywheel can change your VE during throttle transitions. Basically, the crank speed dropping much faster than with the elephantine stock flywheel tossing it around.
Old Dec 23, 2002 | 08:23 PM
my car is a 99 with 45k miles on it , i mostly use 87 octane, but ive had premium in the car and it runs the same. I think im just running lean or something. Its the loss of power im worried about, i was in my moms 01 legacy gt w/ no mods and it seemed to pull harder from 60 to 80 than my car and hers is an AUTO! lol
Well, her car does have the same motor as yours, and 3rd in a 4EAT falls between 3rd and 4th in the 5MT, so 60-80 is one particular range where her car car could feel faster. You'd spank it 50-70 though.
Old Dec 23, 2002 | 08:27 PM
I just paid to have the entire front half of the car re-wired, the ECU replaced and the MAF replaced, so right at the moment, I have no engine management in the car.
What are you getting? sounds like the makings of a monster setup.
Old Dec 23, 2002 | 10:16 PM
Crappy. Was it excessive knock or did the electronics go belly up?
