fenderwell intakes
Old May 29, 2004 | 09:25 PM
kravdra's Avatar
Car Info: '99 Impreza OBS
fenderwell intakes
It probably seems really obvious, but O well, I'm pretty stupid. Where does the air enter the fenderwell from? wheelwell, fog light, under car... Seems like air flowing through the fender wouldn't be ideal due to lack of air flowing into the well, but obviously I'm wrong. Also, is Ganzflow, or cobbtunings better? or can you even tell a difference? Any other intakes I should consider? (I have a 99 OBS if it matters) Thanx
Old May 30, 2004 | 10:50 AM
Lavery's Avatar
Car Info: 98 Impreza RS
The fenderwell is not airtight, meaning that air can easily flow in/out of it. The idea is that the air is colder further away from the engine. I have an Injen intake on my 98 rs. I works as well as the others. I also hear that COBB makes a good one. I don't think there is a "wrong" choice to be made.
luke
Old May 31, 2004 | 09:36 PM
kravdra's Avatar
I was looking at the ganzflow website (its cheaper, and I might be able to get a used 1) but it says there only for post 99 imprezas (something about the MAF or airflow sensor thingy. Does this mean it wouldn't benefit my '99 impreza?
Also, I want a fairly quiet intake (I don't like loudness, in my opinion all loudness does is draw attention, and it doesn't really go with a 130hp car, is one significantly quieter than the others? or are they all fairly quiet ? or is it not possible to get a better intake without getting lots of noise?
Thank you lotsly, I know its probably annoying to answer every newbs intake questions over and over again
Old May 31, 2004 | 09:38 PM
kravdra's Avatar
Luke: that makes sense, but still two questions I guess. Isn't there a big hole in the fender in the engine bay, so wouldn't most of the air, or at least a bit of it come from the "hot engine compartment? Also, if you went through water (not sure I ever will, but if I were too) would it reduce the depth I could go through since a lot of the air would seem to come from the very bottom of the fender? Thanx
Old Jun 28, 2004 | 05:42 PM
Mat - 98 R/T's Avatar
Car Info: '98 Neon R/T
I don't think the fender is going to put the filter as at-risk as you'd make out Rally. I ran a much riskier and more powerful intake on my Neon. Basically, the end of the filter (it sat upside-down) was at the same level as my airdam (6" off the ground). I ran a prefilter on it, and got nothing but good results. I never had any worries unless I was driving on a flooded road...in which case I'd turn around and search for higher ground. I even drove the car like that in a wicked snowstorm with no problems. Any filter that is more guarded than mine was (or in a higher location) should have no issues with weather or muck.
10wrx89
Jun 14, 2014 07:18 PM
MPOWERD
Oct 1, 2004 02:41 PM
OakosAutomotive
Vendor Group Buys/Specials
Nov 14, 2003 02:53 PM
Collins
Dec 27, 2002 04:29 PM
Bean
Dec 17, 2002 12:05 PM
