Expected life of O2 sensor?
Old Jun 16, 2003 | 03:02 PM
Definitely get the code pulled. If you can't find a place to do it free, just have the dealer do it. Make it clear to them though that by charging you for the service, they will NOT be authorized to perform any repairs of any kind.
Anyways, living in Kansas, perhaps you're lucky enough to live near Peaty. He can answer any question you may have.
As for the exhaust, it is indeed a Stomung single tip made specifically for Cobb. It's good stuff. If your cats and headers have heat shields, they are stock. If the headers are tarnished bronze color, and one side runs around the front of the oil pan, they are probably Borlas, which will cause a CEL. Some intakes can also contribute to a CEL.
Old Jun 16, 2003 | 11:27 PM
As a matter of fact, I have the Borlas and a couple weeks ago I got the CEL. Haven't had it pulled yet, but I really doubt it's anything but Cat Inefficiency. I'm going to wrap them as soon as I get my midpipe in, and I'll post results if it clears the light. I believe the light is caused by the cat not reaching light-off temp due to the heat loss from the Borlas. (I'm not the first to say this obviously ) I'd rather fix it right then run an end-around on my ECU.
Kostamojen
May 25, 2004 10:14 PM
elgo
Mar 12, 2004 12:54 PM
Kbi
Sep 18, 2003 04:37 PM
KingTiger
Apr 8, 2003 09:36 AM
Subycharged
Mar 2, 2003 12:53 AM
